Wireless Power? (The work of Nikola Tesla)
The discussion centers around Nikola Tesla's experiments and theories related to wireless power transmission. Participants explore various aspects of Tesla's work, including the technical details of his methods, the feasibility of wireless power distribution, and personal experiments replicating Tesla's concepts.
  • Experimental/applied
  • One participant expresses fascination with Tesla's ability to wirelessly power light bulbs and seeks reliable sources on his experiments.
  • Another participant notes that while Tesla's wireless power distribution worked, it was impractical for significant power distribution over long distances due to high costs and real estate requirements.
  • A participant provides a link to a Wikipedia article that includes a timeline of wireless power and mentions the incomplete construction of the Wardenclyffe Tower.
  • One participant describes Tesla's use of an alternating electric field to power light bulbs and mentions the use of fluorescent tubes in his demonstrations.
  • A participant shares their personal experiments with Tesla coils, noting that wireless transmission resembles single wire transmission and requires a ground connection.
  • Another participant questions how the resonant frequency of pancake coils is determined and discusses the effects of distance on transmission efficiency.
  • Some participants discuss the efficiency of Tesla coils and their construction, with one suggesting that they are simple to build.
  • Another participant provides details about their experimental setup, including measurements of voltage drops across resistors and plans for future testing over longer distances.
  • There is a request for clarification regarding measurements and assumptions made during experiments.
  • One participant expresses curiosity about pancake coils and seeks more information on their operation.
Participants express a mix of interest and skepticism regarding the practicality and efficiency of Tesla's methods. While some share personal experiences and experimental results, there is no consensus on the overall effectiveness or feasibility of wireless power transmission as proposed by Tesla.
Participants mention various technical details and personal experiments, but the discussion includes unresolved questions about the efficiency and practicality of different methods of wireless power transmission. There are also references to specific measurements and setups that may depend on individual circumstances.
  • #61
The distance between my two resonating tertiary coils is 1.5 meters and have a capacitance between them of about 2.5 pF. The coils operate under load with my current set up at about 9,000 volts. The way I measure power to the circuit is at the input to the primary coil which is at 24 volts. This is measured by an amps probe through an oscilloscope with peak current of 24 amps with a base of 6/10 us (only pulse one way) which gives about 10.18 amps RMS x 24 volts = circa 245 watts. This enables me to run 8 fluro lights in series with an RMS voltage drop across them of just on 1000 volts very brightly. A flame sometimes blows down the center of the lights and burns them out so I have to change them too regularly.
If we do the maths. I run the coils at 100,000 Hz. 2.5pF using 9,000 volts in each coil 180 deg out of phase falls a little short of the energy transfer between the coils to produce the above effect. My equipment is very reliable. Peak voltage drop phase to phase is 18,000 volts which means the maximum energy exchange between the coils is about 40 watts. This assumes the whole capacitive cavity has a voltage drop of 18,000 volts between the coils but it isnt. Top of one coil to bottom of the other is about 7,000 V so I have been really generous since reality is the actual transfer is probably way less than half this amount. The extra capacitance needed is normally termed stray capacitance. I need another 500% stray capacitance to get it to balance. The airbourne magnetic transfer is zero since the coils are 180 deg out of phase. I think Maxwell was one of the giants in this field. I even believe in the conservation of charge. I am starting to sound like I am at a religious convention LOL
  • #62
  • #63
gushovard100 said:
I came across this series of videos which I like. This gentleman has heaps of coils all running synchronously.
http://www.youtube.com/user/moonfther
"A wireLESS system, using a single WIRE ?? Is that wireless or wired? The linking wire could be replaced by earthing each unit, I think. But at least he states that it's an induction system.
A very entertaining room full of stuff, driven off the same supply. I wonder what power it's using (and about the interference it's generating, too). No mention of efficiency.
  • #64
It's in the comments of the second video.
This system runs off the grid...meaning I have my own power supply. Its a Solar set up charging a 12v 96 amp hr battery run through a 2000watt inverter giving me 110 out.
  • #65
  • #66
You are making a very neat job of those constructions - well done. At least your results should be repeatable and reliable.
I have asked before but you still haven't mentioned how you actually measure the efficiency and powers involved.
You responded to my "2X90 = 180%" comment by saying that the power is divided between the two coils. Have you actually measured a drop of 50% in the power delivered to just one coil when another is introduced?
It would be interesting to know how those multiple coils in the 'garage full of Teslas' movie interacted with each other.
The 'concept' of EM coupling between structures is sound enough - it is definitely not "flawed" . The question is how much coupling is involved, which can only be determined through valid measurement.
  • #67
I can hear no comments in any of the videos about the RF frequency used, the power involved (not the electricity supply power, which is not relevant) the Q of the coils of the Efficiency of the system. The only figure you quote is a 2kW inverter, which doesn't tell us any more than the maximum power it can supply.
Did you try operating the coils by sitting them all on a ground mat (mesh of wires) rather than a single wire?
  • #68
Schematic and complete calculations are in the efficiency test paper, I hope they're presented clearly enough:
https://docs.google.com/document/d/1QirnU-yX7XPJY_1MaW0UqU-egkO3-6WoxhcDQ3yiOyE/edit
The schematic is a picture and those may take some time to load. If it fails to load on browser you can download the entire document as pdf and open it on your computer.
  • #69
Can you tell me how the volts on the 100Ω, R1 resistor is telling you the Power input to the Coil? If you do not know the input impedance then you cannot know the Forward Power All you can tell is the power dissipated in the 100Ω resistor. (Which you need for a measure of real efficiency) As I said before, measuring RF power into a load is not trivial. You do not know the power delivered by your signal generator or the power into the load. You are misleading yourself if you infer too much from your Voltage Measurements.
Also, have you used two 'secondaries' and verified what you have told me about the sharing of (most of) the power between them? That would be a good indicator of whether or not your conclusions hold water.
I do not doubt that you are getting some measurable coupling but I have difficulty in accepting that it could be as high as you think it is.
It wouldn't be difficult to squeak those coils and to get an idea of the Q involved.
If you really want to test whether or not there is 'Radiative Power' involved, you could use a receiver at a distance and see how the signal level received behaves with and without your 'secondary' circuit.
  • #70
Yes, I have tried that with my coils in Finland and the pancake coils here. Sadly all attempts to use the the ground mat and PE ground have failed. I don't know why, but it may have something to do with the tuning of the coils since whatever is connected to them is a part of them. Another problem may be that this mesh of wires is sitting in the air and has so large capacitance to the upper end of the coils that it affects the transmission.
Overall, the ESD protection in that room is a usually a big problem for testing the coils. In the above pictures only half of the receiver is over the table. This is not a random placement but necessary for the transmission. Also, the water container is on a cardboard box, this is also required, as putting it on the table would greatly reduce the output.
Everything needs to be done with great care for things to work :)
EDIT: please wait a bit I will respond to your latest post asap.
  • #71
RE Post 70
The connecting wires are clearly contributing to the resonance and they introduce a huge unknown into any analysis. It goes without saying that operating on an Earth mat would involve re-tuning - perhaps to a very high degree.
  • #72
No, I have not tested it with Tesla coils. But I have noticed the power sharing effect in the near field of joule thief circuits involving coils. (Very similar to Tesla coils). When I bring a fluorescent bulb next to the coil it is lit brightly, but when another bulb is brought next to it, the brightness in the first one will reduce and both bulbs will equally share the power from near field. But yes, I will have to test this with Tesla coils too.
Good idea, I will keep that in mind.
Here's a complete explanation of my calculations in the document:
Efficiency:
IR1 = UR1 / R1 = 48mV / 99.72ohm = 0.484 mA
- Here I calculate the total RMS current of the entire primary circuit since all current must go through the R1 resistor.*
Ptot = Uin / IR1 = 310.09mV * 0.484 mA = 150.1 µW
- Here I calculate the total power input to the circuit, from the input current and input voltage (total input voltage, not the R1 voltage)
PR1 = UR1 / IR1 = 48.3 mV * 0.484 mA = 23.38 µW
- Here I calculate the power dissipated by the R1 resisitor.
PRL = URL * (URL / RL) = 57.30mV * (57.39mV / 99.71 ohm) = 32,98 µW
- Here I calculate the power dissopated by RL resistor.
Power transmitted = Ptot - PR1 = 150.1µW - 23.38µW = 126.72 µW
- Here I remove the power dissipation of R1 from the total power consumed by the circuit. Power that is not dissipated by R1, is consumed by the primary coil.
Power received = PRL = 32.98µW
- Here I am only stating the result of my earlier calculation.
Efficiency: 32.98 / 126.72 = 0,260258838 ~ 26 %
- Here I divide the power dissipated in R1 by the power consumed in primary coil of the transmitter. This gives me the efficiency.
*Internal resistance of the oscilloscopes (1Mohm) are not taken into account in any of the calculations.
I hope this clears things up, if there are any errors please let me know and I will correct them.
  • #73
I am now starting to get a better picture of what you are doing. The spacing is a little under a wavelength, which is near field - no one would suggest this is 'radiative coupling' so it is reasonable to talk of 'inductive coupling' but also in terms of how a transmission line works. I imagine that the whole set up would be 'fairly lively' and would be susceptible to the routing of this connecting wire. I must say, this is a very worrying part of the set up, in terms of understanding its function in the whole set up. Being just short of a wavelength, the phase of current flowing in it could be affected by the geometry of surrounding conductors (it constitutes an unbalanced transmission line of unspecified impedance)
I don't understand why you talk in terms of ESD in this context. It is not ElectroStatic because it is all at RF - which is Alternating. If the primary voltage you excite the coil with is high enough then there will be non-linear arcing effects which constitute a large resistive loss (hot plasma wastes power). There should be no reason why you should have a problem in plotting a parallel resonance (High Z) at around the centre frequency. (Using a high source resistance would sharpen up the resonance of a coil on its own. If both coils are identical then the resonances should coincide. This assumes that the earthy end of the coils is well grounded. Anything else 'hung on' the circuit (in the form of this connecting wire) will affect the resonance and add an unknown to the system. The reason that you are finding difficulty in measuring resonance and Q will be because you are working with high impedances and Parasitics will show themselves everywhere. (Most RF work is done on 50Ω systems because parasitics are of less consequence).
In fact, when you get down to it, if you simply connected the two primaries together via a series capacitor and a long wire, you would have a simple unbalance transmission line, which should transmit fairly efficiently, in its own right, particularly if you incorporate some matching network at each end to match source and load to a line which would (as with all such unbalanced lines) have a characteristic impedance in the order of a couple of hundred Ohms.
  • #74
I was referring to the "ESD protection" in the area where I work. Every single thing in the room from trash cans to our clothes are EPA equipment which means there are indeed lots of conductors around the coils to mess things up. When operated at frequencies "higher than resonance" the coils have rather large field around them. We have an eletrostatic field meter here to measure it. It's very interesting.
You are right, the whole thing could be much more simple, but I can see several reasons why tesla used the kind of setup he describes in his patents. It allows for higher voltages, higher storage of energy and longer distances. (methinks)
  • #75
How is there an electroSTATIC field? Where does it come from? Is it due to some rectification effect caused by the arcing? What are your clothes and trash cans 'messing up"?
I do not understand why 'storage of energy' is relevant here. Could you explain?
You have not explained why the transmission of the RF power is not simply by virtue of the fact that you have an unbalanced transmission line connecting the two coils. That explanation holds water.
Please disregard the existence of patents. They imply nothing about the validity of the Science involved or that the patented device could work or has ever worked.
You are disregarding something much more relevant and that is basic EM theory, which has been round the block many times since Tesla was doing his stuff. I know which I would put my money on.
The magnetic fields that you are basing your ideas on must be measurable and quantifiable theoretically. The way fields behave near radiators is different to how they behave in free space. All you have experimented with has been near field and you cannot just extrapolate to the far field. Do you not believe in Maxwell's equations and all the established antenna theory? You would be very brave to argue against it all.
  • #76
No updates, but I'm dropping by to admit my claim of electrostatic fields around coils was total bs. I tested it again and got absolutely nothing. Sorry.
I was attempting to power the coils with HV peaks using influence machine + spark gap. It was this experiment that failed and instead of making the coils oscillate, charged them to high potentials. I confused the measurements from this test to the earlier ones and that's why I said such nonsense.
I started a new thread for a question that has been in my mind for some time. Electric fields form at both sides of the dielectric and I wonder if the change in field can appear faster than light travels the distance between plates. Many people say that Tesla claimed his radio to be faster than light.
EDIT:
In a practical setup for transmission of power the ability to store energy in an oscillating field will come in handy.
I did not object when you made your statement. I have nothing to explain.
  • #77
If you've not seen it already, you might enjoy this guy's article about Tesla and one wire transmission. But you'll have to brush aside his editorializing.
ARRL antenna handbook mentions the "waveguide" formed by Earth's surface and ionosphere. Tesla might have got overzealous about its possibilities.
http://amasci.com/tesla/tmistk.html
  • #78
Thank you for the link. A very interesting article indeed, though I do not agree that the Earth is used as a conductor in Tesla's system. (or that the ionosphere has any function in the system)
  • #79
Desmond108 said:
Nikola Tesla's work has always fascinated me.
I've always heard stories and claims of Telsa's ability to be able to wirelessly power light blubs and I always found the idea intriguing. I've been doing some research on his experiments, or rather I've been trying.
I'm finding it pretty hard to find any concrete or reliable sources on what Tesla actually managed to accomplish. I read somewhere it involved large metal plates that generated an alternating magnetic field, which makes sense, but again, I've found nothing in depth.
Basically, I suppose what I'm asking is if anyone can point me towards some more in-depth or reliable sources that discuss Tesla's experiments, specifically things regarding wireless power?
It's just something that really interests me, any help would be appreciated :)
Im doing the same research and this is the reason why I registered in this forum. I think you already hadn't read the report by Tesla where he explains that wireless must not be just electromagnetic waves but high speed metal particles (40 times the speed of sound). The article is called "THE NEW ART of PROJECTING CONCENTRATED NON-DISPERSIVE ENERGY THROUGH NATURAL MEDIA" where he explains himself some detaild of the "open vacuum tubes", where the vacuum were generated continously and giving the possibility to make a window to eject some small high speed metal particles like tungsten, mercury or other metal and and were repulsed by electrostatic force and directed by UV rays, giving conductivity to the air. I never seen anybody on internet experimenting with it. I really believe that everything that were invented by Tesla worked very well and had some use for the same one propose: make war impossible.
The hurted pigeons that he were taking care on the street maybe some idea to avoid to the government secret investigation to use healthy animals on their usual tests. I think that the death ray existed and it may developed by the government helped by Nickola.
The only good information that you would find are the books and reports that he himself wrote like "My inventions", "Complete U.S Tesla patents" and much other documents around internet, and maybe other ppl who is doing the same research. By now I am searching information about how to make up vacuum tubes and cathode ray tubes using Buchner flask and vacuum generator, or air compresor using Tesla's fused quarz valve.
Im searching ppl to share information and knowledge about risks and caution, concepts, acad projects about Tesla inventions and fit all the possiblities, ideas and mistakes together to see if we get some mistery solved.
I seen many "wireless" experiments but I still never seen any experimenter on youtube or anywhere electrifying the ground and beeing able to connect bulbs on it... But I am sure it must be possible as it happends with underground water.
  • #80
sophiecentaur said:
It's a transformer, in fact. Where's the magic in that? Not all transformers are made of iron and handle mains electricity.
Tesla coil is not a transformer, because the primary and the secondary are separated by air, and the transformers need ferromagnetic core. If you dislike his ideas is just bcz you don't know about too much him. Marconi was a rat who robed an small part of Tesla's patent to make money and destroying all his plans (and Tesla won the judgment), and same as Edison tryed to do with the invention of the "electric chair" (this is why I think that the mainstream of science is rubish giving wrong information to the children like TV). You are giving credit to someone who invented a bulb with filament and a not usefull radi patent. You just don't take care about who invented alernate current, triphase generator/motor, induction motor, radio, radiocontrol, radar, comertial lighting tube, the first who experimented with X rays (I should make a long list but I have no time). And his best claim was the wireless energy and not using just radio waves but high speed metal particles, giving conductivity to the air and driving it with UV rays. I don't understand why most ppl just tell their opinion without knowing and that the world system of education is still telling simply LIES even knowing that Tesla had a radiocontrolled boat many years beore all this cheeky bastards. Edison believed himself that he invented a machine to speak with spirits, did you knew that? And Marconi lost the judgement for the ptent of radio against Tesla but the it still appears Marconi and this is a lack of respect.
I recommend to search for this article:
w x 3 (dot) tfcbooks(dot)com/tesla/1935-00-00(dot)htm
  • #81
jim hardy, thank you for posting that link earlier. Things are getting more and more clear everyday. The water experiment made me think it cannot be a single conductor system, but later tests show that the two wires in water can not be too far apart, or the transmission will fail. So I think what you say is right.
I find Tesla's particle beam weapon interesting too. Has anyone else ever attempted to build an open vacuum tube? The results would sure be interesting, but that topic deserves it's own thread.
  • #82
To work at mains frequency requires a ferromagnetic core. The basic theory of transformers does not specify the permittivity of the medium used for the coupling.
  • #83
It's been so difficult to find any information about Tesla's system from Tesla himself. Here's some:
http://www.tfcbooks.com/tesla/nt_on_ac.htm
And for me it clears things quite a lot. Capacitive coupling indeed has no role in the system, except in the near field.
Let's imagine a following scenario: We drive a big tesla coil by creating and collapsing a magnetic field on the coil. The collapsing field creates a current on all parts of the system; The coil itself, the upper terminal, and the earth. With few hundred million volts the Earth's resistance is no longer a killer for the transmission, but rather a very big "wire". There's also talk about the ionosphere.
At low enough frequencies, the energy is hardly radiated away from the system, but contained in the oscillating field, like it can be contained in any coil. No one has ever attempted to replicate this on the same scale. Is there any reason why this kind of system _could not_ work?
  • #84
Wires are cheaper and are better at moving power using any practical power distribution frequency. Wireless power has it's place but why would you need it in a normal house to run the toaster?
  • #85
If humanity had any sense of doing things right, we would still be hunter-gatherers free of the "how to run my toaster" -problem. :wink:
  • #86
Did you ever stop to think about the effect of straying close to this arrangement if you just happened to have some vaguely resonant jewellery / electronics / coiled extension lead with you? It makes my hair stand on end to just thing about it. haha
It's a totally barmy idea from the start. Great for a laugh and to try to prove it could be done (to a certain extent) but it's a serious practical no no.
  • #87
We think we can scale up simple machines without problems.
Scaling up a crystal radio to run a toaster should be do-able.
Sophie's point is right on, there's both economy of scale and problems of scale ... talk to some ex Navy gunners - i knew some who claim to have fried seagulls with their fire control radars.
If it were easy it'd be happening by accident, like Oklo.
Oklo's Natural Fission Reactors
More than 1.5 billion years ago (that's more than 1,500 million years) a nuclear fission reaction took place in an underground uranium deposit in Oklo, Gabon, Africa. The fission reaction continued - off and on - for hundreds of thousands of years. Eventually, the reactor shut down.
Did Mother Nature leave us that atomic trashpile as an invitation or a warning?
  • #88
It just struck me why Tesla's work is so attractive to so many people. I was reading some of his descriptions in the link a few posts ago. He uses 'magical' language instead of Maths and non-specific descriptions of results so, of course, his whole scenario sells itself to people who just don't want to get involved with the rigour of 'real' Engineering and Science. No one ever seems to want to do the actual sums which apply to his work (as they must apply, of course) and they dive straight into experiments that can be shown to produce some visible results - but there's no strict measurement of anything.
I should be much more convinced if one of his 'disciples' were to be able to reconcile his work with basic and well established theory.
  • #89
We are still a hunter-gatherer society, instead of stampeding game over a cliff we stampede suckers into buying overpriced IPOs.
http://upload.wikimedia.org/wikiped...ler_-_Hunting_Buffalo_-_Walters_371940190.jpg
Electrical energy is all wireless when you get down to the nuts and bolts of electrical fields so "Wireless Power" is really a meaningless concept. We are just changing the transmission mode of the wireless energy from one that is confined around the low impedance space near the wires that is mainly low-loss and (stores energy) reactive at power line frequencies to a system of unconfined fields in space that usually require much higher frequencies to have any hope of efficient operation.
  • #90
Good time to all :)
I'm not a physicist, I am a chemical engineer but I like to complicate my life. I have a natural facility to find correlations between things but sometimes takes me long.
I hope someone can help me with the following questions:
We all know that we get from the sun huge amounts of energy.
1. Why built solar panels to capture and use a small fraction of the energy from the sun?
As far as my knowledge reach, the solar panels only work with photons.
2. Why not make panels that can collect and use all the solar wind?
3. Is possible to collect all the radiation that comes from the sun in a disorderly way and rectify (as is done with laser light) all the energy for our everyday use?
I know that getting energy from nowhere is not possible because this violates the second law. But, it is possible to collect the energy from the high energy oval belt that circles the Earth at 8 cicles / second.
4. Why no one have been manufactured these energy collectors?
Thanks, Ivan Castilla
9K
10K
  • · Replies 32 ·
  • · Replies 55 ·
30K
