Find the weight of a box sliding on a floor....
A force of 180 N is needed to slide a box on a horizontal floor with a coefficient of friction of 0.32. The weight of the box can be calculated using the equation that relates frictional force, coefficient of friction, and normal force. The correct approach involves expressing the weight as the force of gravity, rather than calculating mass. The initial calculations were incorrect as they did not properly relate the variables. It's important to clarify that the problem specifically asks for the weight, not the mass, and assumes the force is applied horizontally.
Migi Alarcon
A force of 180 N is required to slide a loaded box along a horizontal floor. If the coefficient of friction is 0.32, what is the weight of the box?
I'm not knowledgeable about any solutions able to retrieve the correct answer since the mass of the box is absent. I have tried
180 = 0.32 (9.8)
180 = 3.13
and M = 57.50 kg
but I'm just not certain about it. I'm really stuck on this one but there must be a solution.
Find and write the equation that relates the co-efficient of friction to the force of friction and the normal force. That will help you understand if your approach is correct or not.
My suggestion is always write down equations in terms of variables, first, and only plug in actual numbers at the end.
So pick some variable names. Maybe Ff for the force of friction, cf for the coefficient of friction and Fg for the force of gravity. Write down an equation relating these variables, and then solve for Fg. Note: the problem is asking about the weight of the box, rather than the mass of the box. The weight is just the force of gravity. You could then solve for the mass of the box from the force of friction, but the problem doesn't ask you to.
Migi Alarcon said:
180 = 0.32 (9.8)
180 = 3.13
and M = 57.50 kg
As they stand, the first two lines make no sense. Presumably you meant
180 = 0.32 (9.8)M
180 = 3.13M
You correctly found the mass, but as stevendaryl points out, you are asked for the weight, not the mass.
There is another possible snag. You have assumed the force is to be applied horizontally. It asks for the force "required", which suggests the minimum magnitude of force over all possible directions.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
