Work Done by Friction Force: A 4.0 kg Block
A 4.0 kg block is pulled over a rough surface by a 20 N force, increasing its speed from 3.0 m/s to 5.0 m/s over 5.0 m. The initial calculations focused on the change in kinetic energy but neglected the work done by the applied force and the energy lost to friction. The correct approach requires calculating the work done by the applied force and subtracting the kinetic energy change to find the work done by friction. The misunderstanding stemmed from not accounting for the applied force's contribution to the overall energy balance. Properly considering all forces involved is essential for accurate work calculations in physics.
IKonquer
A 4.0 kg block is dragged over a rough horizontal surface by a constant force of 20 N. The speed of the block increases from 3.0 m/s to 5.0 m/s in a displacement of 5.0 m. What is
the magnitude of the work done by the friction force during this displacement?
My work was the following:
Ei + W = Ef
(.5)(m)(3)^2 + W = (.5)(m)(5)^2
And as a result, I got W = 50 - 18 = 32 J.
I'm not sure why this answer is wrong. Thanks in advance.
You've calculated the energy that went into raising the speed from 3 to 5 m/s. But you haven't calculated the energy that was lost to friction.
Hint: How much work did the applied force do?
I see. I just didn't realize that I needed to account for the applied force.
Thanks again.
