Work and Kinetic Energy problem
The discussion focuses on a problem involving a force Fx acting on a particle with a mass of 1.5 kg, defined by the equation Fx = Cx^3, where C = 0.50. Participants clarify that C, while a constant, has specific SI units that must match on both sides of the equation. For calculating work done as the particle moves from x = 3.0 m to x = 1.5 m, integration of Fx is discussed, with the integration constant being irrelevant for definite integrals. The work-energy theorem is applied to find the final speed of the particle at x = 1.5 m, using the work calculated from part B. The conversation emphasizes the importance of unit consistency and proper application of integration in physics problems.
maniacp08
A force Fx acts on a particle that has a mass of 1.5kg. The force is related to the position x of the particle by the formula Fx = Cx^3, where C = .50 if x is in meters and Fx is in Newtons.
a) What are the SI units of C?
b)Find the work done by this force as the particle moves from x=3.0m to x=1.5m
c)At x = 3.0m, the force points opposite the direction of particle's velocity(speed is 12.0m/s). What is its speed at x=1.5m?
For A:
Isn't C just a constant? What units is this in?
For B:
I have to integrate Fx and the integral of F(x)dx = x^4/4
Since C is a constant I can put it in front of the integral so is 1/4 C x^4
When I integrate shouldn't there be a + K? 1/4 C x^4 + K
X1 = 3.0 and X2 = 1.5
Plug in and solve?
For C:
Using answer from Part B = Work total
Work total = 1/2 M Vf^2 - 1/2 M Vi^2
where Vi = 12m/s?
maniacp08 said:
For A:
Just because C is a constant doesn't mean it has no units. Hint: For any equation, the units on each side must match.
For B:
Good.
Plug in and solve?
Since you are doing a definite integral (between limits) the integration constant goes away. Just evaluate between those limits.
For C:
where Vi = 12m/s?
Good. Use the work-energy theorem.
