Work and Kinetic Energy Question.
The discussion revolves around the work-kinetic energy theorem, specifically regarding the loading of a refrigerator onto a truck using a ramp. The key point is that the total change in kinetic energy is zero when the refrigerator is moved at constant speed, meaning the work done by the man is equal and opposite to the work done by gravity. The claim that increasing the ramp length would reduce the work required is examined, and it is clarified that while the man does work to change the potential energy, the net work done on the system remains zero. This is because the work done by the man and the work done by gravity cancel each other out. Understanding this balance is crucial for grasping the concepts of work and energy in this scenario.
elementis0
Hey guys, I am learning about the work-kinetic energy thereom and I am having trouble with a concept of it which arose from an example problem in my book.
Here it is:
A man wishes to load a refrigerator onto a truck using a ramp at angle theta, he claims
that less work should be required to load the truck if the length L of the ramp were increased.
Is this claim valid?
Basic Kinetic Energy and Work Eqn's
Ok so I know how to solve the problem pretty much, my question on this problem is more a conceptual question.
In order to solve the problem I must notice that the total change in kinetic energy is zero, and this is because of what the book says which is "For the system of the fridge and the hand truck, the change in kinetic energy is zero. the normal force exerted by the ramp on the system is directed at 90 degrees to the displacement of its point of application and so does no work on the system"
But why is this? The fridge is moving isn't it? So if it has a velocity and is going a distance shouldn't there be kinetic energy from the work by the man?
I know when looking at net work I should look at the work being done by the entire system,
but I can't help but thing that the gravity is doing no work but that man is, therefore work is being done and kinetic energy is positive, but the book says the work done by the man added to the work done by gravity is zero?
Would love to have this question cleared up to help my understanding of this concept!
Where is my logic flawed?
Here it is:
yes, but it is assumed to be moving at constant speed, so that implies the initial and final kinetic energies are the same, since v is the same at the beginning and at the end; thus, there is no change in the KE of the system
the work done by the man changes the potential energy of the system
W_net = delta KE; since delta KE is 0, then W_net is zero. The work done by the man is the negative of the work done by gravity, that is, the work done by the man is mgh in any case, regardless of the angle of incline to reach the same height.
So then also in that case,
would the change in potential energy be mg(del_h)?
Yes, where delta h is not given, but it would just be the vertical height from road grade to the top of the ramp (floor of the truck).
