prace
- 102
Me again
http://album6.snapandshare.com/3936/45466/776996.jpg
More correctly they describe the height the fluid must be lifted- the fluid might be directed horizontally for a while but that would not require any work. In any integral, the limits of integration give the minimum and maximum values of the variable of integration. Here x represents the height any "piece of oil" or "layer of oil" must be lifted.I am still not understanding what the difference is between the limits of integration for a problem like this and the x inside the integral. Aren't they both describing the distance the fluid must flow?
Not quite. The force (weight) of each thin layer of water is actually [itex]4\pi \rho dx[/itex], the volume of a thin disk times the density.Also the [itex]4\pi \rho[/itex] makes sense here as being the Force that needs to be applied.
Again, not quite. You seem to be thinking "force times distance" as "constant in front of integral times integral". That's not the case. In both problems, x is the "distance". It just happens that the force in the second problem is a constant and so can be taken out of the integral. Of course, [itex]x\sqrt{9- (x-7)^2}[/itex], is not a "distance"- look at the units. If x is measured in feet then that is feet squared. It's actually the area of a "layer of oil". multiplying it by density and "thickness", dx, gives the weight or force needed to lift it.So taking this force times the distance (integral) gives us the work. Right? So does this mean the expression I had for work in the first equation, [itex]x\sqrt{9- (x-7)^2}[/itex], is just distance and has nothing to do with Force?
The purpose of "Me Again: A Smile to Brighten Your Day" is to provide uplifting and positive messages to readers, in order to bring a smile to their faces and brighten their day.
The target audience for "Me Again: A Smile to Brighten Your Day" is anyone who could use some positivity and encouragement, regardless of age, gender, or background.
Unlike other self-help or motivational books, "Me Again: A Smile to Brighten Your Day" is a collection of short, simple, and relatable messages that can be easily incorporated into daily life. It aims to provide quick and easy doses of positivity, rather than lengthy and complex advice.
While "Me Again: A Smile to Brighten Your Day" is not a replacement for professional help, it can certainly be beneficial for individuals struggling with mental health issues. Its positive messages can serve as a reminder to focus on the good things in life and to keep going during difficult times.
As a scientist, I can confirm that while "Me Again: A Smile to Brighten Your Day" is not backed by specific scientific research, its messages are based on principles of positive psychology and have been found to have a positive impact on individuals' well-being. Additionally, the book includes references to reputable sources such as TED Talks and psychology studies to support its messages.
