Work done by friction homework help
The discussion focuses on solving a physics problem involving friction and work done by forces on a block. The key equations for calculating the friction force and work done are presented, with an emphasis on the correct signs for each calculation. The friction force is determined to be 4.13 N, while the work done by friction is initially calculated as -5.14 J, which is noted to be incorrect. The correct approach highlights that friction does negative work as it opposes motion, and the work done by the applied force is calculated using the angle and displacement. Clarifications on the problem setup and equations are provided to aid understanding.
mandy9008
(d) Let m = 2.00 kg, x = 3.50 m, θ = 32.0°, F = 17.5 N, and µk = 0.400, and find the answers to parts (a) and (b). (Include appropriate signs.)
(a.) friction force vector f k
(b.) work done by friction
(c.) work done by vector F
a. mu_k(mg-Fsinө)
b. mu_k(mg-Fsinө)x ...** wrong!
c. Fxcosө
a. 4.13 N
b. -5.14 J ...*** wrong!
c. 51.94 N
I'm having a hard time understanding the problem, maybe you can clarify a little more.
I had to find equations only using symbols, then solve them. the equation for part b is wrong though
But, is this an incline plane problem. Where is F acting, can you sketch it?
Sorry, I didn't realize that I wasn't posting the entire problem
(a) A block with a mass m is pulled along a horizontal surface for a distance +x by a constant force vector F at an angle θ with respect to the horizontal. The coefficient of kinetic friction between block and table is µk. Is the force exerted by friction equal to µkmg?
Enter the expression that describes only the magnitude of the force exerted by friction. (NOTE: Use mu_k to represent either +µk or -µk, q for θ, and m, g, x, and F as appropriate.)
mu_k(mg-Fsinq)
(b) How much work is done by the friction force and by vector F ? (Don't forget the signs.) (Use mu_k for µk, q for θ, and m, g, x, and F as appropriate.)
work done by friction mu_k(mg-Fsinq)x my answer (wrong)
work done by vector F Fxcosq my answer
friction force vector f k 4.13 my answer
work done by friction -5.14 my answer (wrong)
work done by vector F 51.94 my answer
this is pretty universal.. a is correct if x is displacement w=fd
w=mu_k(mg-fsinq)d
w is negative of course because it is acting against the movement.
The force exerted by friction is Ff=(µk)(mg-Fsin(theta)). Friction is doing negative work because it opposes motion. Work done by friction is -(µk)*Ff*x. Work done by the force is F*cos(angle)*x. Does this help?
