Work done by friction on an incline plane
The discussion focuses on solving a physics problem involving work done by friction on an incline plane. The user outlines their approach, including the calculation of the normal force and the work done by friction using the coefficient of friction. They express concern about the complexity of their solution and seek a more straightforward method. Additionally, they inquire whether they need to solve for acceleration when applying Newton's second law. The conversation emphasizes the importance of simplifying equations in physics problems.
idllotsaroms
http://postimage.org/image/gprwhko37/
Could someone check my work to make sure I'm doing this problem correctly?
Where:
s : hypotenuse or distance
h : height
uk : coef friction
W = F*D
Force Normal = mgcosθ
Wfriction = (uk * N) * s(distance)
Solve for θ to use to find force normal
Sinθ = h / s
θ = arcsin(h/s)
Y component of weight of box = mgcos*arcsin(h/s)
Fy = may = N - mgcos*arcsin(h/s)
N = mgcos*arcsin(h/s)
Then plug N into equation Wfriction = -uk * N * s
Wfriction = -uk*mgcos*arcsin(h/s)*s
After a few extraneous equations, the result looks right.
Thank you Rude man, but how would I remove the extraneous equations? Could you show me an alternate shorter way to go about doing this?
Also, would I have to solve for a when using Fy = may = N - mgcos*arcsin(h/s)?
Where:
h : height
uk : coef friction
W = F*D
Sinθ = h / s
θ = arcsin(h/s)
Omit the red.
see above.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
