How Is Work Calculated on an Elevator Cab in Physics Problems?
The discussion centers on calculating the work done on an elevator cab by the force from a cable while considering the forces acting on both the cab and a block of cheese inside it. The solution manual's approach is questioned, particularly the inclusion of the normal force as an external force when analyzing the system. Participants agree that the correct equation should either exclude the cheese's weight when calculating the cable force or treat the forces acting on the cab separately. The consensus is that the solution manual's method is flawed, and the alternative equations provided are valid for determining the work done on the cab. Clarification on the treatment of internal versus external forces is crucial for accurate calculations in physics problems involving systems.
user14245
The problem
A 0.250 \operatorname{kg} block of cheese lies on the floor of a 900 \operatorname{kg} elevator cab that is being pulled upward by a cable through distance d_1 = 2.40 \operatorname{m} and then through distance d_2=10.5 \operatorname{m}. Through d_1, if the normal force on the block from the floor has constant magnitude F_N = 3.00\operatorname{N}, how much work is done on the cab by the force from the cable?
From Fundamentals of Physics, 9th Editon, Problem 25, Chapter 7
My solution manual
Here is what my solution manual says:
The net upward force is given by F + F_N-(m+M)g = (m+M)a where m=0.250 \operatorname{kg} is the mass of the cheese, M = 900 \operatorname{kg} is the mass of the elevator cab, F is the force from the cable, and F_N = 3.00 \operatorname{N} is the normal force on the cheese. On the cheese alone, we have F_N - mg = ma, and etc..., the solution continues
My question
I do not see why the first equation is correct. To me, the force F_N is internal between the cab and the block, so once one considers both as a system and applies the Newton's second law, the equation should read F - (m+M)g = (m+M)a.
Is the solution manual wrong, or am I overlooking something?
Thank you.
It's about the notation as you could have done it your way, that is split the F into Fn(cheese) Fc(cab) and you would get the same result. In your notation you just consider F as the total force not just the force that acts on the cab. The question is how much work is done on the cab, and not cab + cheese.
Thank you.
Putting aside the issue of work for a moment, the solution manual for the calculation for the force in the cable is incorrect. Your equation is correct.
Alternatively, if you want to calculate the cable force by first incorporating the normal force exerted by the cheese on the cab, then you must not include the cheese weight in the formula, because it is not part of the FBD for forces acting on the cab.
So, use either
F - (m+M)g = (m+M)a, or
F - F_N - Mg = Ma.
