Work done to move a point charge
The discussion focuses on calculating the work done to bring three point charges, q1, q2, and q3, to specific points in an equilateral triangle configuration. The initial work done to bring the first charge, q1, from infinity is zero since there are no other charges present to exert force against. The participants clarify that potential energy calculations for subsequent charges must consider the interactions with previously placed charges. The correct approach involves calculating the potential energy contributions from each charge and summing them accordingly. Ultimately, understanding that the first charge incurs no work simplifies the problem-solving process.
dfetnum
Three charges, q1, q2, and q3, are located at the corners of an equilateral triangle with side length of 1.49 m. Find the work done in each of the following cases:
a) to bring the first particle, q1 = 1.33 pC, to P from infinity
b) to bring the second particle, q2 = 2.99 pC, to Q from infinity
c) to bring the last particle, q3 = 3.29 pC, to R from infinity
d) Find the total potential energy stored in the final configuration of q1, q2, and q3.
W=qV=kqq/r
I've tried doing kq1q2/r +kq1q3/r and got 5.05E-14 Nm but I don't think this is the correct method
W=qV=kqq/r
I've tried doing kq1q2/r +kq1q2/r and got 5.05E-14 Nm but I don't think this is the correct method
Calculating differences in potential energy is the correct method. But which part is that supposed to be the solution of? Start with a).
that is my attempt at a. I need to find the potential energy from the two different charges and then add them
When you move the first charge in there are no other charges around. You haven't placed any other charges yet. a) should be super easy.
so, what equation would that be? The one I am using still has a radius and a place for a second charge
The initial charge is q=0. Put that in.
oh wow, I didnt realize that the total work done was zero if there was no other charge to push against it. Cool, I figured out the rest. Thanks
Right. Moving the first charge in is free.
