Work with Friction: Calculating Force & Angle
  • Thread starter Thread starter dator
    Friction Work
The discussion revolves around a physics problem involving work, friction, and forces acting on a wagon being pulled by a parent. The scenario includes a combined mass of 50 kg for the wagon and child, with a specified work done of 2.2x10^3 J over a distance of 60 m, and a coefficient of friction of 0.26.
  • Mixed
  • Participants explore the relationships between the forces acting on the wagon, including normal force, frictional force, and the applied force. There are attempts to derive equations based on the given parameters and to analyze the balance of forces in both horizontal and vertical directions.
Some participants have provided guidance on checking the setup of equations and ensuring that the forces are correctly represented in the free body diagram. There is an ongoing examination of the calculations, with participants questioning the accuracy of the equations and the assumptions made regarding force directions.
Participants are discussing the implications of their calculations and the need for careful consideration of force directions, particularly regarding the frictional force and the applied force. There is a recognition of potential errors in the setup of equations and the importance of verifying each step in the problem-solving process.
dator
In many neighbourhoods, you might see parents pulling youngsters in a four-wheeled wagon. The child and the wagon have a combined mass of 50kg and the adult does 2.2x10^3 J of work pulling the two 60m at a constant speed. The coefficient of friction for the surfaces in contact is 0.26.
a) Draw a FBD of the wagon
b) Determine the magnitude of the force applied by the parent.
c) Determine the angle at which the parent is applying this force.
F_friction = mu*F_normal
a^2=b^2+c^2
Work=Force*(delta)d*cos(theta)
Just want to make sure I did this right. And do I have to include the units when i write formulas out? (N*M) etc. It it important too or it doesn't matter? Thanks in advance!
Variables:
Work = 2.2x10^3 J
(delta)d= 60m
mu = 0.26
Force = ?
Theta =?
In Terms of y:
F_normal=-(mg+Force*sin(theta))
In Terms of x:
Since speed is constant acceleration=0, therefore F_x+F_friction = 0 or (F_x=-F_friction)
Let:
Force*sin(theta) = F_y
Force*cos(theta) = F_x
In terms of x:
Work = Force*(delta)d*cos(theta)
Force*cos(theta) = Work/(delta)d
F_x = 2.2x10^3/60
F_x = 36.77777776
Therefore F_x+F_friction = 0
F_x+mu*F_normal = 0
Sub in numbers.
36.7+(-1)(0.26)[(50)(-9.8)+Force*sin(theta)= 0
36.7+(-0.26)[-490+Force*sin(theta)]= 0
36.7+127.4+(-0.26)(Force*sin(theta) = 0
Force*sin(theta) = -164.1/-0.26
Force*sin(theta) = 631.1538462
F_y = 631.1538462
F_y = 631.1538462
F_x = 36.7
Force = sqrt(F_y^2+F_x^2)
Force = 632.38N
tan(theta) = opp/adj
opp = F_y
adj = F_x
(theta) = tan^-1(F_y/F_x)
(theta) = 86.6
(theta) = 87
a)cant draw it here, but the F_normal has the F_y going parallel with it, and F_fr is opposing the F_x.
b) 632.38N
c)(theta) = 87
Hello dator,
Welcome to Physics Forums!
a^2=b^2+c^2
Variables:
Work = 2.2x10^3 J
(delta)d= 60m
mu = 0.26
Force = ?
Theta =?
In Terms of y:
In Terms of x:
Let:
In terms of x:
F_x = 2.2x10^3/60
F_x = 36.77777776
F_x+mu*F_normal = 0
Sub in numbers.
According to my calculations, something is not right with the very last line above.
I think the root of the error might come from your equation:
The vectors are not adding up (or subtracting up) right. Rearrange the above equation to put all the terms on one side of the equation; then set all that to zero. Compare that to your FBD.
In the future, if might be beneficial to work the problem in smaller steps, rather than trying to combine everything into one big monster step. For example, after you calculate the force of friction (which you did early, and that's okay), calculate the normal force. That way you can check if things make sense before moving on to the next step. :wink:
collinsmark said:
Hello dator,
Thank you! :)
Bah, I should plugged the numbers back in and checked the statement I made, F_x+F_friction=0. The F_y I solved for does not give me a true statement.
Statements should be as follows then,
F_normal = -(m*-g+Force*sin(theta))
F_normal = (mg-Force*sin(theta))
Therefore, F_x+F_friction = 0 is:
Force*cos(theta)+(mu)(mg-Force*sin(theta)) = 0
36.7+(0.26)(490-Force*sin(theta)) = 0
36.7+127.4-(0.26)(Force*sin(theta)) = 0
Double check...
36.7+(0.26)(490-631.1538462)=-0.0000001
So basically zero, blame it to roundoff.
Does that look good now?
Thanks, in advance!
dator said:
Thank you! :)
dator said:
Thank you! :)
No, something is still not quite right. :wink: Both the frictional force, and the horizontal pulling force are both in the same direction. They need to be in opposite directions. Try placing a negative sign in front of the 36.7.
Double check...
Thanks, in advance!
Your double checking should show that something is not right. The vertical pulling of the parents has a greater magnitude than the gravitational force. The parents would pulling the wagon so hard that it would accelerate up into the air! :-p
  • · Replies 38 ·
