Did I Solve This Work with Variable Force Problem Correctly?
The discussion revolves around a textbook problem involving a particle moving against a variable force while experiencing constant acceleration. The user calculated the work done using the formula W = ∫(2x/a + ma)dx, arriving at W = mah + h²/a. However, this result differs from the book's answer of W = 4h/3 √(3mh), leading to confusion about the book's methodology. The user questions the book's omission of acceleration in its calculations and points out inconsistencies in unit compatibility. Overall, the user believes they have solved the problem correctly and suspects an error in the textbook.
suffian
I just did the following textbook problem (from my Calculus book under the chapter review from Applications of Integrals) but came up with an answer that differs from the one at back of the book:
A particle of mass m starts from rest at time t = 0 and is moved along the x-axis with constant acceleration a from x=0 to x=h against a variable force of magnitude F(t)=t2. Find the work done.
Calculus and Analytic Geometry by George. B Thomas
I reasoned as follows:
The force I need to apply at any given time t to maintain constant acceleration would need to be t2 to cancel out the force acting against me plus ma to maintain a constant forward acceleration. In other words F(t) = t2+ma.
If the acceleration is always a and the particle starts from rest at x=0 then
x''(t) = a
x'(t) = at
x(t) = at2/2
This means that once the particle reaches a position x, the following amount of time has elapsed:
t(x) = sqrt(2x/a), t > 0
Which in turn leads to the force that needs to applied at a given position x:
F( sqrt(2x/a) ) = 2x/a + ma
We now use the work formula W= ∫a..b F(x)dx :
W = ∫0..h (2x/a + ma)dx
W = mah + h2/a
On the otherhand, the book gives the following result:
W = 4h/3 sqrt(3mh)
I don't see how they arrived at their results since it doesn't take into account the acceleration of the particle. Surely, the faster the particle is accelerated the work should take toward a limiting value of mah(force * distance) because the particle will reach its destination faster and therefore have less resistance to deal with (remember the resistance was t2). But the book doesn't ever consider the acceleration.
Has the book made an error, or have i misinterpreted the problem?
Mathematics news on Phys.org
man, the units don t even work out right for the answer the book gave. that s a sure fire way to tell a wrong answer.
plus, i didn t see any mistakes in your work.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
