Writing Uncertainty in terms of dA, dB, dC
The discussion centers on deriving the uncertainty formula for X, defined as X = [(A)(B^2)] / C, in terms of dA, dB, and dC. Participants debate whether the correct expression for (dX/X)^2 should include terms for dA, dB, and dC, with one suggesting it should be (dA/A)^2 + (2dB/B)^2 + (dC/C)^2, while another proposes a different formulation. The conversation emphasizes the importance of correctly applying logarithmic differentiation to avoid errors in the uncertainty calculation. Participants are encouraged to start over using the natural logarithm approach for clarity. The thread highlights the complexities of uncertainty propagation in mathematical expressions.
ZedCar
Write down formulae for dX in terms of dA, dB, dC if:
X = [(A) (B^2)] / C
I'm using the formula below as this corresponds to this relationship.
(dX/X)^2 = (dA/A)^2 + (dB/B)^2
For the first line, not the actual solution, I'm getting either:
(dX/X)^2 = (dA/A)^2 + (2dB/B)^2 + (dC/C)^2
or
(dX/X)^2 = (dA/A)^2 + (dB/B)^2 + (dB/B)^2 + (dC/C)^2
Then if I follow through on either line, I get a different answer.
I was wondering which is the correct line to begin with?
I think it's the second option.
Thank you.
Hi ZedCar! :smile:
(try using the X2 button just above the Reply box :wink:)
X = [(A) (B^2)] / C
No, you should never get any squares of differentials. :redface:
Start again, with lnX = lnA + … :smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
