Y=y(x) of a particle on the xy plane experience F=-kr
The discussion focuses on deriving the equation y = y(x) for a particle of mass m moving in the xy-plane under the influence of a force F = -kr directed towards the origin. The motion is described using the position vector r(t) = A_{1}cos(wt) i + A_{2}cos(wt) j, where 'i' and 'j' are unit vectors in the x and y directions, respectively. The solution involves isolating x from the r(t) formula and substituting it back to obtain y, which requires solving two second-order differential equations and determining initial value constants.
  • Understanding of Newton's second law (F = ma)
  • Familiarity with differential equations
  • Knowledge of vector calculus in two dimensions
  • Experience with harmonic motion concepts
  • Study the derivation of solutions for second-order differential equations
  • Learn about harmonic motion and its mathematical representation
  • Explore the application of initial conditions in solving differential equations
  • Investigate the role of forces in particle motion in physics
Students studying classical mechanics, physics enthusiasts, and anyone interested in the mathematical modeling of particle motion in two dimensions.
Animastryfe
Assume a particle of mass m which is free to move on the plane x-y. The particle is
experiencing a force F = −kr towards the origin. Find the equation y = y(x) that
describes the motion of this particle on the plane.
F = ma = -kr
The 'i' and 'j' above should be unit vectors in the x and y direction, respectively.
I think I'm supposed to use the r(t) formula above to isolate x, then substitute it back into the equation to get y?
You have two second-order differential equations, one for the motion in the x plane, and another for the motion in the y plane. you are missing two initial value constants.
Thank you for the reply. I figured it out shortly after.
