Solving Yo-Yo Force Problem: Find Acceleration & Friction Force
  • Thread starter Thread starter Ruitker
    Force
The discussion revolves around solving the acceleration and friction force of a yo-yo subjected to a horizontal force while rolling without slipping. The user attempted to calculate the torque by taking moments about the center of mass, leading to the equation R*fr - r*F = I*alpha. There was a query regarding the direction of the torque from friction in relation to the applied force. The user ultimately found their calculated answers to be incorrect, indicating a need for further clarification or correction in their approach. The problem highlights the complexities of rotational dynamics and the importance of accurately accounting for forces and torques.
Ruitker
A yoyo of mass m=2 kg and moment of inertia ICM=0.0625 kg m2 consists of two solid disks of radius R=0.25 m, connected by a central spindle of radius r=0.1875 m and negligible mass. A light string is coiled around the central spindle. The yoyo is placed upright on a flat rough surface and the string is pulled with a horizontal force F=28 N, and the yoyo rolls without slipping.
The force is applied at the top of the spindle; so above the center of mass.
Find the acceleration of the yo-yo.
Find the frictional force
F-fr=ma
Tq=I*alpha
I started taking moments about the centre of mass, which came to R*fr - r*F = Torque
Then equated this with the Inertia and alpha.
Then changed alpha to a/R.
So ended up with a = ((R*fr - r*F)*R)/I
I then use the F-fr=ma equation to solve for both fr and a.
The answers i get are incorrect.
F-fr=ma
Tq=I*alpha
Are you sure the torque of the friction acts against the torque of the applied force?
ehild
