Where Can I Find a Surface Mount to DIP Adapter for a Custom Part?
  • Thread starter Thread starter akhurash
    Adapter Surface
A user is seeking a surface mount to DIP adapter for a custom part with a 4.40mm distance between two surface mount contacts. They are unable to create their own adapter and have had difficulty finding a suitable off-the-shelf option. Suggestions include using Emulation Technology, which offers both standard and custom adapters, and considering a ZIF socket wired to a prototype board for easier testing. The discussion emphasizes the need for a safe and efficient solution to connect multiple custom parts without soldering. The conversation highlights the challenges of finding compatible adapters for unique specifications.
akhurash
I'm trying to find a surface mount to DIP adapter for a custom part. The length between the two surface mount contacts is about 4.40mm. I attached a simple drawing of the part. I'm having a hard time finding a DIP adpater because the part is custom made and I was wondering if anyone knows an adapter that would work. I can't make my own.
There are only two contacts total? So you want to make an adapter from 2 SMT pads to 2 through-hole socket pins? Or are there more contacts in the pattern that you have not shown?
For adapters, I've used Emulation Technology with good success:
http://www.emulation.com/
They also can make custom adapters (for a fee) if nothing is available off-the-shelf.
Thank you for the reply berkeman. Yes, I need an adapter from 2 SMT pads to 2 through-hole socket pins. I have to test multiple of these custom parts and I thought it would be easier and a little safer to put them on an adapter rather than soldering wires to them (like how I have been doing).
For just 2 pads, I'd wire them to a ZIF socket's top two socket locations, and mount the ZIF socket on a small prototype board and bolt that to something (the SMT board, for example). Would that work?
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
