Resultant Couple and direction angle
The discussion revolves around calculating the resultant couple and direction angles for a bent pipe subjected to multiple forces. The forces include a 100lb force downward, a 125lb force along the y-axis, and additional forces acting in both the x and z directions at various points along the pipe. The poster expresses confusion about determining the components of the resultant couple and how to incorporate distances into the calculations. They seek clarification on breaking down the forces and relating them to the distances involved. Ultimately, the poster indicates they resolved their confusion shortly before the deadline.
Bradracer18
Ok, I have 3 couples applied to a bent bar. The axis is with the z going up, y left and right, and the x basically out of the page(or kinda to the left a bit).
The pipe goes 28in to the right(on y axis), where the pic show a 100lb force pointing down from the +z direction, and a 125lb force keeps going along the y axis. The pipe then bends and runs parallel with the +x axis, and goes for 16in. A 150lb force from the +x direction points back into the pipe, and a 125lb force points at the pipe from the +y direction. This is also where point A is. The pipe then bends downward(-z) for 9in. At the end of the pipe, a 100lb force is applied towards the +z. A 150lb force is also applied at the end, in the +x direction.
Determine, the magnitude of the resultant couple C and the direction angles associated with the resultant couple vector. Then also determine the scalar component of the resultant couple C about line O(orgin)A.
I think I drew this out right...you just have to draw as you read. Should go towards +y, then towards +x, then -z.
I think I add the x,y,z components of the couple(C). Then I think I square each of them, add them together, all under a square root.
For the angles, I think I just take the cos-1 of each component/mag of C.
I'm not sure how to find the components. I think I understand how to break them down(simple), but I don't really get how to relate the distance in there. If someone could do one that would be helpful(or explain it). I'm not sure where to take the total distance from I guess either.
Thank,
Brad
Is this problem understandable?? Or do I need to draw a pic? I didn't draw one on paint, because usually they are too small/blury to see.
can anyone help...this is due today. I think I can get it, if I can get some help on how to find the individual components...I'm not sure how to relate the forces, and the distances.
Figured it out...thanks for all, that attempted to solve it(I know, it was complicated to read). I even had 2 hrs to go...haha...Thanks again!
