How do I find Capacitor rating to start / run Single phase motor
To refurbish a 1.1KW single-phase motor missing its start and run capacitors, it's suggested to contact an industrial supplier for assistance, though availability may be limited in regions like Malawi. Calculating the required capacitor ratings can be challenging, but typical values for a 230VAC motor are around 16-22uF for start capacitors. Basic tests can be performed without a starting capacitor by manually spinning the motor to check if it runs with just the running capacitor. It's important to consider that the motor may have a centrifugal switch that disconnects the starting winding and capacitor at higher speeds. Understanding these factors can aid in troubleshooting and determining the necessary components for motor operation.
sharper1968
I am trying to refurbish a 1.1KW single phase motor (1445 RPM) but both start and run capacitors are missing.
How can I calculate what capacitors are required.
Motor is Rated 7.2 A (220 VAC)
Look forward to your help.
Thanks.
Call an industrial supplier and give them the make/model of the motor. They will set you up. Do you know why these items are missing? There is usually a good reason for it. Something else is wrong with the motor and the 2 capacitors were salvaged?
Thanks for your reply, which unfortunately is not a lot of help in my circumstances.
I am in Malawi, Central Africa, and "industrial suppliers" are very thin on the ground. Being in Malawi is also the most likely explanation for the capacitors being missing - in Africa if you don't use it you lose it! It is of course possible that the is a problem with the motor, but I have done a few basic tests and I think it is ok. Obviously replacing the capacitors was the best place to start.
Is there not some way to calculate the likely ratings so I at least have somewhere to start with trial and error?
Many thanks.
I'm sure there is a way to calculate it, or a typical set of guidlines for it. However, I wouldn't know what they are. I DO know that the values will be similar for similar types of motors of a given horsepower rating and voltage. You do realize that you don't need a starting capacitor to do a few basic tests? If you have the running capacitor installed and just leave the starting capacitor out, NOT bypassed, just leave the terminals unhooked, apply power to the motor and manually spin the motor in either direction. The motor should spin up. Of course you haven't tested the starting winding, but you might look into wiring a bunch of light bulbs in parallel with each other but in series with the starting winding (in place of the capacitor). If it does start on it's own, it will not have much starting torque, but it should prove that the starting winding is good if it does spin up on its own.
Just a note. It's probably not the case here, but I have seen motors where the start windings (and capacitor) get disconnected form the circuit once the armature speed is high enough. The motor has a centrifugal switch on one of its shaft ends.
After some google searching; looks like for a 230vac motor, the start caps are 16-22uF.
Regard
Regard
If the motor has a starting capacitor as well as a running capacitor then I am sure that the starting capacitor is switched out after a certain RPM. I assumed that was a known.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
