Combining ions to make ionic compounds
To combine two different ions into an ionic compound, one must balance their charges. In the example of sodium (Na+¹) and oxygen (O-²), sodium has a +1 charge and oxygen has a -2 charge, leading to the formula Na2O, which indicates two sodium ions are needed to balance one oxygen ion. Ionic compounds consist of a positively charged cation, which readily loses electrons, and a negatively charged anion, which attracts electrons. Understanding the distinction between ionic and covalent bonds is crucial for grasping these concepts. This foundational knowledge is essential for successfully creating ionic compounds.
jleposky
How do i combine 2 different ions to make an ionic compound
Na+¹ + O-² --->
I have no idea what to do plus I am new to this forum. Please try to help me in the simplest way possible because my teacher has failed twice to explain it to me. If their is a formula or something, please tell me it.
Does one mean stoichiometrically, or structurally as in a crystal lattice.
In the example, Na prefers +1 valence state, while O prefers -2, so the compound in that case would be Na2O. For ionic compounds the positively charge cation is usually electropositive, and tends to give up electrons readily to the negatively charged anion, which is electronegative, i.e. has an affinity for electrons.
Also, see discussions about ionic compounds.
http://en.wikipedia.org/wiki/Ionic_compound
http://chemed.chem.purdue.edu/genchem/topicreview/bp/ch7/sizeframe.html
http://www.shodor.org/UNChem/basic/nomen/index.html
One has to understand the difference between ionic and covalent bonds
http://antoine.frostburg.edu/chem/senese/101/compounds/ionicvscovalent.shtml
http://en.wikipedia.org/wiki/Ionic_bond
http://en.wikipedia.org/wiki/Covalent_bond
http://hyperphysics.phy-astr.gsu.edu/hbase/chemical/bond.html
How did you figure out Na2O from Na+¹ + O-²?
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
