Why Does f'(x) Have Only 3 Critical Numbers on (0,10)?
  • Thread starter Thread starter Hothot330
    Numbers
Hothot330
The first derivative of the function f is given by f '(x)= (((cos^2)x)/(x)) - 1/5
How many critical numbers does f have on the open interval (0,10)?
I already got this question wrong but I don't know why I got it wrong. The answer is 3 but when I graph it I see 6 critical numbers. So why is it 3 and not 6? Please explain.
Let's clear up any confusion about what the problem is ...
f'(x)=\frac{\cos^2 x}{x}-\frac 1 5
Correct?
Correct
I tried taking the derivative of the derivative and graphed that but it still gives me an image of 6 critical points.
I don't understand why that would happen. A critical point occurs where the derivative is 0 or does not exist. Clearly your derivative does not exist at x= 0. To determine where f'= 0, I graphed y= 5cos2(x) and y= x. They cross in 3 points.
Wait, did you differentiate again? You said what you gave was f '. To determine where f has critical points, you should be graphing that, not its derivative.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
