Emf and internal resistance of a battery
The discussion centers on determining the electromotive force (emf) and internal resistance of a battery based on voltmeter and ammeter readings. When the switch is open, the voltmeter reads 3.07 V, indicating the emf, while closing the switch drops the reading to 2.95 V with a current of 1.70 A. The terminal voltage is the emf minus the voltage drop across the internal resistance, leading to the equations E = I(r + R) and E = Ir. Participants clarify that with the switch open, there is no current, and thus the internal resistance cannot be calculated directly from the open circuit. The conversation emphasizes understanding the relationship between emf, terminal voltage, and internal resistance in circuit analysis.
StephenDoty
When switch S in the figure is open, the voltmeter V of the battery reads 3.07 V. When the switch is closed, the voltmeter reading drops to 2.95 V, and the ammeter A reads 1.70 A. Assume that the two meters are ideal, so they do not affect the circuit.
Find the value of the emf. (see picture posted below)
the equation would be
E-Ir-IR
or E= I(r+R)
E=Ir
however I am totally confused on how to find the internal resistance value,r, when the switch is open and the value of R when the switch is close. Any help would be appreciated. Thanks. I apprecaite the help.
Stephen
I'm a bit puzzled by this problem, since the battery EMF is given. Are you being asked to find R and r?
E-Ir-IR
or E= I(r+R)
That's one equation. E and I are given.
Write another equation describing the given voltage reading across the battery terminals when the switch is closed.
I have two equations there. Are they right? What would the emf be? the 3.07V or 2.95V? And how would you find the r and R?
Thanks
Stephen
You must have snuck the second one in after I had posted. The one I saw is certainly correct. The other is just Ohm's law.
The terminal voltage across the battery (which is what the voltmeter measures) is the EMF minus the voltage drop across the internal resistance (which is given by Ir). When the switch is open, what's the current through the circuit?
By combining two equations. The one I quoted from your first post and another that you should write for the terminal voltage when current flows.
So use 3.07 for E in E=Ir and 1.7 for I thus r=3.07/1.7=1.81? Then to find the emf you do the voltage 3.07 + (1.7)(1.81)?Then to find R would you use 2.95=I(r+R)=(1.7)(1.81+R)?
Are these right?
No. Reread what I said about EMF, terminal voltage, and internal resistance. Note that 3.07 is measured when the switch is open.
Well doesn't this mean that the emf = the voltage measured by voltmeter +the voltage drop, Ir? and to find r you use E=Ir or 3.07=(1.7)*r?
If this is not right I need a little bit more info? The concept is not sinking in.
No. Note that the terminal voltage (in this setup) is the voltage measured by the voltmeter. So that means: Measured voltage = EMF - Ir.
And the current (I) depends on whether the switch is open or closed.
From your equation EMF = Measured voltage +Ir
right?
And since the switch is not closed what would the current be when the voltmeter measures 3.07V? And then how would you find r from the equation E=Ir? Would you use the 3.07V for E and the current found above for I? If this is not right, would you please guide me to the right direction. Thanks.
right?
Yep.
You tell me. When the switch is open you have an open circuit.
I have no idea my professor only went over closed circuits. Since the circuit is not closed, I do not see how a current exists. But since the voltmeter is giving a measurement there is obviously a current. Need a starting step.
V=Ir or I = V/r, but since we do not know r, I do not see how we can solve it.
That's just the point: With an open circuit, there is no current. I = 0.
Not true. The voltmeter measures voltage, not current. You don't need a current to have a voltage.
