What is the coefficient of static friction in this scenario?
The discussion centers on deriving the coefficient of static friction (us) from a free body diagram of a block on a flat surface. The user expresses confusion about incorporating the block's weight into their calculations, as they have established that at equilibrium, the pulling force (Fpull) equals the friction force (Ffriction) multiplied by us. It is clarified that the correct relationship is Fpull = Fnormal * us, where Fnormal is the normal force acting on the block. The user is conducting an experiment to determine us and explore whether it depends on surface area or mass. The conversation emphasizes the importance of understanding the forces acting in both the horizontal and vertical directions to accurately derive us.
yoleven
from the free body diagram of a block resting on a flat surface, I am trying to derive the coefficient of static friction.
I have the definition of the coefficient as:
us=Fn/Ffr
But in my free body diagram i am pulling on the block, which resists with the Ffr
I have
\SigmaFx=0
F-Ffrus=0
us=F/Ffr
My confusion is because if the definition of the coefficient is above, why don't I derive it when I observe my free body diagram of the block. What am I missing?
The forces in the x direction are my pulling force and the friction force that resists it * us
How do i get the weight of the block into my derived equation?
The weight of the block is Fn.
(If that's not what you're looking for, please state the complete problem exactly as it was given.)
It is not a problem as such. I am trying to determine the coefficient of static friction us experimentally. Then, I am trying to determine if it is a function of surface area or of mass.
My experiment consists of a wooden block on a wooden flat surface. I am going to attach a spring scale and determine at what force the block overcomes the friction and moves.
In trying to determine us from my free body diagram I am having a little difficulty as I tried to explain.
From my free body diagram, if at equilibrium the forces in the x plane are zero, I get
Fpull-Ffriction*us=0
but I don't see where I am getting the mass of the block to become part of my derived equation.
you also need to apply Newton's second low in the Y-direction (vertical direction)
ma_y = F_normal - mg = 0
do you understand this equation ? Why is it equal to 0 ?
ps a_y is the component of the acceleration in the vertical direction
and F_normal is the normal force.
In this case, this is not going to help you much because the table is horizontal.
marlon
What you should get is Fpull - Ffriction = Fpull - μFnormal = 0.
Thank you.
yoleven said:
Is it correct to state that Fpull=Ffriction*us?
or is it Fnormal=Ffriction*us?
Nope,
Fpull=Fnormal*us
