Calorimetry - Calculating absorbed and released heat
  • Thread starter Thread starter edimeo25
    Calorimetry Heat
The discussion focuses on calculating the heat absorbed by water and the heat released by burning ethanol in a makeshift calorimeter setup. The calculations show that the heat absorbed by 280g of water, with a temperature change of 30°C, is 35.1kJ, which equals the heat released by 20g of ethanol. The molar heat of combustion for ethanol is calculated to be 81.08kJ/mol. Participants also clarify the distinction between Q and ΔH, noting that while they can be identical in some contexts, they differ in others. The calculations and concepts presented are affirmed as correct.
edimeo25
Calculate the heat absorbed by the water in the calorimeter and the heat released by 1,0g of burning ethanol. Then, calculate the molar heat of combustion (kJ/mol) of the ethanol.
The calorimeter used was very makeshift: ethanol in an alcohol burner was lit under a can containing water, both of which were placed inside a hollowed out larger can.
Here is what is known:
mass of ethanol burned = 20g
mass of heated water = 280g
change in temperature = 30"degrees"C
Q(water) = -Q(ethanol)
mc"delta"T = - (mc"delta"T)
280g*4.184J/g"degree"C*30 = -Q(ethanol)
Q(water) = mc"delta"T = 280g*4.184J/g"degree"C*30"degrees"C = 35145.6J = 35.1kJ
Q(ethanol) = -Q(water) = -35.1kJ (for 20g)
Q(per gram of ethanol) = -35.1kJ / 20g = -1.755kJ/g = -1.76kJ/g
Q or "delta"H? (per mol of ethanol) = -1.76kJ/g * 46.07g/mol = 81.08kJ/mol
--> Does this make sense? Is it right? And what is the difference between Q and "delta"H?
Looks OK.
Check enthalpy definition. In some circumstances it is identical to Q, in some it is not.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
