Direction of Friction: Rotating a Wheel Up a Hill
The discussion centers on the direction of friction when a wheel rolls up a hill due to an external force. It is established that friction acts down the hill to enable the wheel to roll correctly, generating the necessary torque for rotation. When torque is provided by an axle, friction still plays a crucial role by acting up the hill to propel the wheel forward. The conversation emphasizes that friction contributes to both linear motion and torque, countering the forces acting on the wheel. Ultimately, the interaction of friction and external forces is essential for achieving rolling motion, whether going up or down a slope.
R Power
Hi guys
Consider a wheel rolling up the hill by some external force. What will be the direction of friction?
I know it's a basic question but i got confused last night with friction in rotation and rolling.
The direction of friction would have to be down the hill in order for the wheel to roll in the correct direction.
"The direction of friction would have to be down the hill in order for the wheel to roll in the correct direction."
if i give it a force then it's ok i understand u or myself
but consider an axle of a car , it gives a wheel a torque , so in this case torque has already been provided so will friction act up the hill?
My original logic in this post was incorrect, so it is deleted (12/06/09)!
A diagram is included with a comment below.
but the reaction force is friction. Isn't it?
Yes. The friction of the road will act up the hill thus propelling the car up the hill.
in this case why will car propell up the hill?
If i apply external force to a wheel , friction will act downwars providing the wheel with torque, which will make it rotate and the linear force i provided combining with the rotation will create a "roll".
But in above case torque is provided b axle it's ok but what about linear component of force required too create a roll. If u say it's friction I say that frition will just give an anti torque i.e just trying to stopp the rotation of wheel. What will give the wheel a linear component??Bcoz linear component together with rotation produces 'roll'.
Friction from the road provides a linear force as well as a torque.
Why will friction provide a linear force. Actually friction provides a linear force a radius distance apart from center of rotation which creates a torque(a torque is always a couple so in this case one force is at the top of wheel due to my push and other and opp is due to friction).
What propells it forward?
Both. The forces come in pairs, otherwise the wheel would freely accelerate when you apply a force to it.
Why would wheel freely acc when i apply force to it? When i would give it force , the force will be on all points on it and also at the top. Now at bottom friction will give an opp force , the couple creates a torque and this would produce rotation but since a linear force was present at all other points too(my force) it would move forward along with rotation and this is called rolling.
F=ma, so if you apply a single force to an object, it will accelerate.
Right - the engine provides a torque in one direction, the friction with the ground provides a torque in the other direction. In constant speed motion, forces come in pairs (at least), that sum to zero.
Sketch attached. Friction is upward and resolved weight of a cylinder/wheel is downward along the plane angle.
If no torque acts independently at the axis of rotation, the wheel is rolling downhill, the friction causes a clockwise torque about the axis applying the right hand rule.
Suppose a second counter-clockwise torque (like at a car axle) acts independently about the central axis. The magnitude of the upward friction force must grow in reaction to this torque to either (a) slow the downward motion; (b) hold the wheel in place on the ramp; or (c) move the wheel up the ramp. I'm fairly certain this description will make sense now.
system theory
consider the case of a wheel going up the hill.
Though i understand the case of wheel rolling down, direction of friction clearly.
What i am asking is : When wheel rolls down firction produces torque and thus rotation and there is a downward motion due to gravity which together with rotation creates a "roll".That's clear .OK.
But when wheel goes up especially wheel on an axle , torque is provided by axle , friction just counter acts to oppose that torque in uphill direction, then what provides linear motion to wheel to roll instead of rotate.
In previous case gravity provided linear motion and friction provided rotation and togehter they both created rolling motion.
But in later case where does linear motion come from?
ReAD CAREFULLY!
The translational acceleration is determined by both gravity and friction.
Friction and gravity once again determine the translational acceleration.
In both cases friction helps determine the linear motion. You seem to be stuck on the idea that friction provides a torque but not a linear force.
ReAD CAREFULLY!
Good idea! :smile:
But friction provides linear force only at the bottom part where wheel touches the ground and that linear force is used for producing torque. Isn't it? Or that linear force also pushes the wheel forward?:confused:
Since friction is applied at a distance from the center, it contributes to the torque on the wheel. But it also contributes to the linear acceleration of the wheel.
Of course it does. When you use Newton's 2nd law to find the linear acceleration, you must consider all the forces regardless of where they act.
Would we all be having such a terrible problem is we replaced the wheel / road / drive shaft system by a lever and just considered the first mm of movement? That's all that's happening, really. It's jut that the wheel provides you with a set of levers one of which is always in contact with the road.
Let me say I give a force of 10 Newton uniformly over whole of a wheel. Now every point on the wheel will have an acceleration coresponding to that force or I can say every point will experience a force of 10 N. The bottom point touching the ground will also experience a force and it will apply same force to ground. Now a reactive force or friction will act on the same point in opp direction. Also, there existed same force on the top most point. So a couple will be formed of 10N each force and the wheel will start to rotate. So now 10 N or whole of friction force is used in creating couple, where does linear component come from?
If u still say friction will give linear component, then relook that force at top point was 10N, so we need a 10N at bottom for rotation to start, so friction provided that 10N which was it's instataneous max. value. So, all 10N used in rotation , where does linear force come from?
I don't know what you mean by applying a 10 N force 'uniformly over the wheel'. Perhaps you mean that you are applying a net force of 10 N on the wheel in such a way as to exert no torque? And you also have another force at the top of the wheel? Please try describing the situation again.
Again, I don't quite understand what you're saying here. Realize that all forces contribute to the linear acceleration of an object. This is just Newton's 2nd law: ΣF = ma. ΣF stands for the net force, including everything.
Think of this: Imagine you are driving a car on level ground. You step on the gas to accelerate. What external force acts on the car to accelerate it?
I didn't have any other force on the top of wheel. I simply applied a force of 10 N to the wheel,so each point on the wheel will experience a force of 10 N. So the topmost point will also experience a force of 10 N. Now bottom point will also experience 10 N force and exert it onto ground bcoz it is in contact with ground. So ground will exert a equal and oppp force of 10 N on it as friction. The 10N force at top and frictional 10N at bottom will produce torque. Friction can't provide any linear force then since all 10N friction is used in creating couple with the 10 N force at toppoint.
Apart from accelerating the wheel (but let's assume it is massless), itself, the force "around" it is irrelevant. What is important is the forces where the wheel is in contact with something else. There is a couple, from the periphery of the shaft - say two forces - one at the top and one at the bottom of the hub. There is another couple, consisting of a forward force from the road, due to friction and a reaction force (backwards) against the centre of the shaft, because of the reaction due to the mass of the car.
I suppose there must be another couple involved, due to the weight of the car which is well forward of the driveshaft, which stops the car from 'wheelying'. (In a front wheel drive, the force is from the rear wheels). This is greater than the couple turning the wheel, so the car goes forward without tilting up. I am finding it difficult to draw a diagram which shows this extra couple and its effect. Perhaps you have to consider it as a reactive couple, appearing against the couple applied to the wheel.
I guess that when a wheely starts, the forward acceleration is briefly less, as the force against the ground is reduced.
RPOWER
If you consider driving the wheel with a roller at the top (which may simplify matters helpfully) then you have one couple, consisting of the roller force and the friction force separated by the diameter of the wheel.
There will also be a couple due to the mass of the car, acting at the axis of the wheel and the reaction force of the road, separated by the radius.
Because of the rigid body, front wheels / the weight of the car (mentioned above) the car can't rotate or deform so the force acts against the mass of the car - pushing it forwards.
The argument would apply if you consider a lever, too.
I must say that, apart from having made me think very usefully, about the problem I don't see where this is getting us.
The system clearly works and all that remains is to reconcile some intuitive thoughts with a bit of real mechanics and to choose the appropriate forces and distances to consider. No one has 'got it wrong'.
sophie,
let us take case of a wheel and i push it with some force , friction creates a couple with force i applied and causes rotation. Now since i provided a linear force (not torque), it will create a roll bcoz rotation+linear motion = rolling motion. Here friction creates rotation and my push on wheel gives it linear motion so together they create a roll. Note that friction doesn't provide any linear movement to wheel here , it only provides it torque.
Do u agree with me? First tell this then we 'll talk of axles.
I don't know what you mean. Did you apply a force of 10 N spread out over the entire wheel? That's not the same as every point on the wheel experiencing a force of 10 N. (That would mean you applied an infinite net force to the wheel.) Extremely confusing!
See above.
No. Just because you (supposedly) are exerting 10 N of force on the bottom of the wheel does not mean that the wheel exerts 10 N of force on the ground.
Again, you seem to be creating some strange arrangement of forces. In any case, you (supposedly) exerted 10 N of force at the top and bottom of the wheel. Those two forces exert a net linear force but no torque. Friction exerts both a linear force and a torque. (A force doesn't get 'used up' in creating a torque!)
Answer my question about the accelerating car.
Wrong. All forces contribute to the net force on the object, which is used to determine the linear acceleration.
Friction does two things: It contributes a linear force and a torque.
R Power said:
sophie,
If your wheel is massless, it will rotate as it rolls with 'zero' friction force and accelerate at an infinite rate. Already, you seem to have introduced a model which I can't get along with. If the wheel has mass, then this is actually adding to the complexity of the next stage of putting in on a car with an axle.
Your friction, in the above case, is actually in the other direction from in the case of a driven wheel.
And, of course, all this would apply equally to a 'rolling road' on which there is no forward motion of a car. Every motion would be rotary.
I'm still not sure what you are arguing about. Have you spotted a flaw in reality?
If something is pushing the cart, then under ideal conditions there will be no friction when considering the cart and the hill only.
Now depending on what's pushing the cart, the direction of friction force will be opposite to the direction of motion of the cart (though friction we get the normal reaction (relative to the cart) which the cart needs to move). Now here I've assumed that that the normal reaction is given by the hill itself...it can be other things too like a propulsion system, in which case the hill will not give the normal reaction and the reaction will even not be through friction.
first of all let me tell you how i applied force. I simply pushed the wheel. U r confused about top point and bottom point experiencing 10N force i think.
See, a body is made of a number of particles(say infinite), when a body accelerates under effect of a force , each particle of body acc by same amount, that means each particle of body experiences same force. This is what i meant.
So the bottom point or particle at bottom or group of particles at bottom and top will also experience a force of 10N.
This is what I meant.
Now reconsider my model and tell me if friction can provide any linear force?
Bcoz friction is produced due to particles of body at bottom hitting ground due to force i applied to wheel. So friction force equal to 10N and opp in direction is produced. This friction force along with force on particles at top creates a couple.
Now particle(s) at top experienced a force of 10N and same is friction's max instataneous value in opp direction. This creates torque. So there is no friction force left to provide linear motion.
Also in this case friction is in direction opp to wheel's linear movement so why it will provide wheel a linear movement . It will just give torque.
But Doc All said it will provide linear movement.
  • #31
I got it. It just struck my mind now! and was so simple.
1.) If I push a wheel then friction helps in rotation by producing torque and my push creates a linear movement (tends to slide the wheel) and together they produce a roll.
2.) If an axle gives torque to wheel, friction provides linear movement and axle provides torque and together they produce a roll.
It was simple.
But Doc ALl confused me:
No my friend I think frictionn will never give both torque and linear force. In the cases above friction either fully provides torque(1.case) or fully provides linear force(2.case). It never does both things. So rethink! u told me that in case 1. friction will give both torque and linear force to wheel , for torque it's ok but how can it give linear forward movement to wheel since it's direction is opp to wheel movement and thus produces torque.However in case of axle providing torque i.e case 2 u were correct , friction will provide linear force but still no torque.
Rethink case 1.
  • #32
Bearing in mind that a couple (torque) is defined as the product of force times distance, I can't recall any textbooks being fussy about where that force came from!
  • #33
If there is a ball on a mat, I can pull the mat towards me. The ball will move towards me AND start to rotate. Nicht war?
  • #34
If you push an object with 10 N of force that does not mean that each particle of the object experiences 10 N of force.
And it still doesn't quite make sense.
All forces contribute to the linear force, including friction.
Friction does not have to equal the force you exert on the bottom of the wheel.
If you exert 10 N at the top and bottom of the wheel parallel to the surface, you've exerted a net force of 20 N on the wheel. If friction provides 10 N in the opposite direction, then the net force is 20 - 10 = 10 N. That determines the linear acceleration of the wheel's center of mass.
The torque is determined in a similar manner. The two 10 N forces you exert produce 0 net torque. The friction force thus produces the net torque.
Once again, it is the vector sum of all forces on the wheel that determine the linear acceleration of the center of mass.
It was simple.
Not that simple. Do not neglect the torque contributed by the friction force.
Nonsense.
Rethink case 1.
I urge you to rethink all of your statements in the light of Newton's laws of motion.
  • #35
OK Doc leave all this(since I've understood) , come to the where we start from , when a wheel rolls up a hill due to torque provided by axle, direction of friction will be up the hill, right??
I think u agreed to me. But in one of my books they have taken it down the hill. Is the book wrong or we are wrong somewhere?
  • #36
A body of mass m and moment of ineria J taken about its central axis rolls down an incline plane with friction limited to the surface contact patch. The body is assumed to be rigid.
Taken in the direction of motion on the plane, the sum of forces acting on the rigid body minus the mass times acceleration equals zero. Let F be the force of resolved gravity and f be the friction, then acceleration is given by:
a = \frac{F-f}{m}
The torque is given by:
T = fr
Angular acceleration about the central axis:
\alpha = \frac{fr}{J}
For a body of mass m, the friction and rates of acceleration are functions of moment of inertia J, so bodies of different inertia have different rates of acceleration down the plane.
Notice a force acting at the center of mass, or at the axis which includes the center of mass, generates zero torque. Also the bearings in a mechanical axle support a force but not a torque. The brakes on such a machine require a structure to couple braking torque to the frame, bypassing the axle, or the brakes would just go round and round with the wheels.
  • #37
For any of this to work, you need a frame. So why not assume that the wheel is massless and that the frame has the mass. Then we need not consider Moment of Inertia - just forces and mass.
No one seems to have read / understood / responded to my statement that it can all be reduced to levers. The wheel thing just adds confusion.
And you can even forget friction if you drive the car / lever on a rack rather than a friction surface. All the basics will remain the same - the essence shines through.
  • #38
I think the study of bodies rolling downhill is a better approach in terms of common sense. Add a counter-torque acting at the central axis in the equations above, and when F - f = 0 the acceleration a = 0 and rotational acceleration alpha = 0, as when a brake is applied.
The moment of inertia J cannot be eliminated from problems of motion because it absorbs rotational kinetic energy, which takes energy away from the translational rotational energy.
Place a body on a frictionless plane and the initial potential energy U = mgh, or mass times standard gravity times height. The only way to account for the slower exit velocity of rolling bodies is to store energy in the rotational inertia J.
I know inertia complicates the example a bit, but I think R Power is trying to visualize the common sense interpretation of rolling motion in bodies and vehicles, so it is worth the effort to make some case studies based on a traditional dynamic solution framework.
Your frame of reference may have merit, but I'm not sure J can be eliminated except under the assumption of constant velocity, and in downhill motion, that is not the case.
  • #39
We really need to sort out the model we are discussing.
Is the wheel a wheel on a massless frame or is it a massless wheel on a massive frame? That would be a much better model to study as it is realistic. If we are talking of cars, the wheel MI is negligible, surely.
If there is no friction, the wheel will not rotate in any case and the car will go nowhere - just slipping down the hill, perhaps.
This thread just goes in circles because no one has decided what we're talking about.
There has been some serious nonsense written as a consequence of several misunderstandings, I fear.
  • #40
Insufficient information. Is the external force greater than m g sin(θ), where θ is the angle of the hill? You need to know the direction of the net force.
Net force = (external force) - (m g sin(θ))
If the net force is up hill, then the friction force is down hill, if the net force is down hill, then the friction force is up hill. If the net force is zero, then there is no friction force. The direction of the velocity doesn't matter, only the direction of the acceleration.
This ignores rolling resistance which can apply an opposing force and opposing torque at the same time to decelrate a rolling object free of any other forces.
  • #41
If i give a force to a wheel uphill where net force is in uphill direction. That's ok!
But if an axle provides torque to a wheel up hill as if a car moving uphill, then what will bw direction of friction?
I think friction will act uphill i.e in the direction of movement of car.
  • #42
Of course it will. It's the only force in an uphill direction to make the car go that way. It's a REACTION force - that means it acts against the force causing it. If the (driven) wheel pushes down the hill the car is pushed uphill because of friction. When g dominates and the car runs downhill, the friction force is uphill and slows the car down.
This is all so elementary. Just think about Newton's laws and apply them here, rigorously.
Yet again, I don't think the situation has been described unambiguously and understood by both sides of the argument. Are we talking driven vehicles or trailers? The difference is significant. There is no point continuing until that's cleared up.
  • #43
I just wanted to confirm this only in the beginning and even I don't know where this thread has gone. In one of my books direction of friction on wheels accelerating up is taken downwards, so I thought I may be wrong in my mind and just wanted to confirm. That was all.
And yeah! we were comparing driven vehicles and trailers, !
  • #44
"Wheels accelerating up"? Driven up or driving up?
That is the whole point. The answer is different for each case.
  • #45
Driven up by axle. No trailer , just like drive wheels of a rear wheel drive car.
  • #46
Ah well, that appears to be wrong. The force ON the ground is downwards; it has to be for the reaction (friction) force to push the car uphill.
  • #47
R Power
system theory
ReAD CAREFULLY!
This sketch shows the rear arm of a shaft powered motorcycle. For simplicity let all torques and forces act on the rear wheel. If the resolved weight for F acts to the right (downhill) a braking torque must be applied (reaction friction force f acts uphill) such that velocity is constant. Thus the motorcycle is either at rest or at constant velocity with F = f.
I hope this picture is "worth a thousand words" as far as the confusion on this thread.
