Lagrange multipliers with two constraints
aclotm81
By using the Lagrange multipliers find the extrema of the following function:
f(x,y)=x+y
subject to the constraints:
x2+y2+z2=1
y+z=12. The attempt at a solution
Using lambda = 1/(2x) I got x=y-z and y=1-z
plugging that into the first constraint, I got:
6y^2-6y+1=0 which makes y=0.5+-(31/2/6)
I got the same thing when solving for z, which means x=0 and lambda = infinity, which doesn't make sense.
You've also got z=1-y. So if you choose the root y=(3+sqrt(3))/2 you have to choose z=(3-sqrt(3))/2 not the other root for z. You can't mix and match any two roots with each other.
Ah, I forgot to distribute the negative! I hate when that happens...it's all worked out now, thanks a lot!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
