What is the reflection coefficient on a transmission line at a resistor halfway?
To calculate the reflection coefficient at a resistor located halfway on a coaxial transmission line, the appropriate formula is Γ_L = (Z_L - Z_o) / (Z_L + Z_o). The value for Z_L should be determined by transforming the circuit to find the equivalent impedance seen by the resistor at the halfway point. This involves calculating the impedance of the second resistor in parallel with the first, considering only the length L/2 of the transmission line. After obtaining the equivalent impedance, the reflection coefficient can be calculated using the standard formula. Understanding these transformations is crucial for accurately determining the reflection coefficient in this scenario.
Rib5
If I have a coaxial transmission line, with a resistor halfway through, and another resistor at the end, how do I calculate the reflection coefficient for the spot where the resistor is halfway?
Here is a diagram of what I mean. Dashes and dots are are the lines, and } are resistors.
...}a...}b
\Gamma_{L} = \frac{Z_L-Z_o}{Z_L+Z_o}
I am pretty sure the formula I am supposed to use is \Gamma_L = \frac{Z_L-Z_o}{Z_L+Z_o}. What I am not sure is what value to choose for Z_L. Do I take Z_o in parallel with R_A?
you know how you can take any length of transmission line plus an impedance at the end, and transform it into a single impedance that the source sees?
Well, put your finger over resistor a and the rest of the circuit, and apply that formula to transform your circuit from
L/2 of wire-> impedance a -> L/2 of wire -> impedance b
into
L/2 of wire -> impedance a -> equivalent impedance B
you need to use the length L/2, not L, when you calculate the equivalent impedance for resistor b, because you're calculating the equivalent impedance that resistor a sees. Next, now that resistor behaves just like they do in your circuits class. Take equiv b in parallel with a (assuming a branches across and connects the wires) to find a single impedance at the "end of the wire" (which represents what impedance is seen at the halfway point). Then apply your reflection equation.
