Maxwell Stress Tensor: Find Elements for Plane Wave in Z Direction
leonne
find all elements of maxwell stress tensor for a monochromatic plane wave traveling in z direction and linearly polarized in x.
Tij=\epsilono(EiEj-(1/2)\deltaij E2+1/\muo(BiBj-(1/2)\deltaB2
So i found what E and B is well not really important to my question but E =Eocos(KZ-wt) X direction
B=1/c Eocos(KZ-wt)Y direction
I have the solution, but kind of confused. They only found Txx Tyy Tzz why didnt they find Txy ext or is that wht it means by find all elements, just xx yy zz
So i found wht Txx is and I got TXX=1/2(\epsilonoE2-B21/\muo they got the same but than that = to zero. Why does it TXX= to zero? Same for Tyy
thanks
Your T_xx is correct. As for the off diagonal terms:
Only one component of E and B are non zero.
The cross terms in the tensor are all of the form:
T_{ij}=\epsilon_0E_iE_j +\frac{1}{\mu_0}B_iB_j with i=/=jLet's consider the x-y term. That is:
T_{12}=T_{xy}=\epsilon_0E_xE_y +\frac{1}{\mu_0}B_xB_y
But, E_y and B_x are zero! Thus, T_xy is zero. Similarly all the other off diagonal elements are zero as well.
o ok thanks for the info
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
