Is max bending stress the same as the yeild strength
Max bending stress is not the same as yield strength; allowable stress, which is a percentage of yield strength, should be used to determine beam section sizes. The factor of safety is applied to the allowable stress, typically calculated as yield strength divided by the safety factor. To find the allowable stress, divide the yield strength by the factor of safety. When calculating the dimensions of a supporting plate, consider various failure modes, including bearing stress and tensile failure, and ensure to assess all potential failure points in the bolting arrangement. Proper calculations and considerations will lead to a safe and effective design.
engtobe
i don't know whether to use the yeild srength or allowable stress to determine section sizes of a beam please help me :)
thank you.
You should use the allowable stress which is a percentage of yield stress (e.g 60% of yield stress).
Thanks for your reply you are very kind
So I use allowable
my factor of safety is 3 but I thought that meant the allowable divided by three not the yield
how would I determine the allowable if that is the case.
Or is it just my yield divided by three equals the max allowable and safe load?
Yes, this is correct.
thanks mate :)
is it possible to calculate the width and thickness of a plate that is helping to support a beam when you have values for shear and bearing stress, a diameter of to bolts and the load it carries.
i have tried using bearing stress = load/diameter*t and then rearanging for t but the answer is wrong.
Bearing stress is one of many modes of failure. Do you have a sketch of your bolting arrangement?
yes i have attached it to this post
You should check failure in both the hinge pin and bolts. In addition to the bearing stress consider:
2) Tensile failure = 2 X La X plate thickness
where La is the distance from the edge of the hole to the edge of the plate.
3) Pin push block out = 2 X d X plate thickness, where d = distance from hole edge to part edge.
