Derivative of inverse tangent function
biochem850
Find derivative of tan^{-1}(\frac{3sinx}{4+5cosx})
deriviative of tan^{-1}=\frac{U'}{1+U^{2}}
I found U'= \frac{12cosx+15}{(4+5cosx)^{2}}
1+U^{2}=1+\frac{9sin^{2}x}{(4+5cosx)^{2}}
I think my components are correct but my answer is still incorrect. Are these basic components even correct (if so I can proceed on my own from here)?
hi biochem850! :smile:
looks ok so far
How do you then simplify:
\frac{U'}{1+U^{2}}?
I've tried to simplify this but with no luck.
Can someone please help me?
hi biochem850! :wink:
(just got up :zzz:)
well, the (4 + 5cosx)2 should cancel and disappear …
show us your full calculations, and then we'll know how to help! :smile:
\frac{12cosx+15}{(4+5cosx)^{2}}*1+\frac{(4+5cosx)^{2}}{9sin^{2}x}=
\frac{12cosx+15(9sin^{2}x)+(4+5cosx)^{2}(4+5cosx)^{2}}{(4+5cosx)^{2}(9sin^{2}x)}
I'm not sure this is correct.
hmm :rolleyes: … let's use tex instead of itex, to make it bigger :wink:
biochem850 said:
\frac{12cosx+15}{(4+5cosx)^{2}} \left(1+\frac{(4+5cosx)^{2}}{9sin^{2}x}\right)=
\frac{12cosx+15}{9sin^{2}x}=\frac{3(4cosx+5)}{9sin^{2}x}
no, that first line is wrong,
the bracket is 1 + 1/U2, it should be 1/(1 + U2)
I changed my work just before you posted
but you didn't change the bit i said was wrong :confused:
\frac{12cosx+15}{(4+5cosx)^{2}}\frac{(4+5cosx)^{2}+1}{9sin^{2}x+1}=
\frac{12cosx+15}{9sin^{2}x+1}
I'm not sure this is correct. I really don't understand what you asked me to change.
change your original …
… to something with (4 + 5cosx)2 on the bottom
\frac{(4+5cosx)^{2}+9sin^{2}x}{(4+5cosx)^{2}}?
yup! :smile:
now turn that upside-down, and multiply, and the (4 + 5cosx)2 should cancel :wink:
\frac{12cosx+15}{(4+5cosx)^{2}+9sin^{2}x}
In terms of finding the derivative I know I've found it but this can be simplified further.
I don't know if I'm tired or what because I cannot seem to do these very simple problems. This does not bode well for my calculus mark. Would you factor out a 3 in the numerator and then see what will simplify?
no, and i'd be very surprised if this simplifies
(except that you could get rid of the sin2 by using cos2 + sin2 = 1 :wink:)
get some sleep! :zzz:​
Through some weird algebraic manipulation I simplified down to \frac{3}{5+4cosx}. I believe this is correct. I'm going to sleep.:smile:
Thanks so much!
