Charged Particle Moving in Magnetic Field
An electron accelerated through 2.4 x 10^5 V enters a 1.7 T magnetic field, raising questions about the maximum and minimum magnetic forces it experiences. The magnetic force is calculated using F = QvB, where the velocity and magnetic field orientations significantly impact the force. The maximum force occurs when the velocity vector is perpendicular to the magnetic field, while the minimum occurs when they are parallel. The calculated speed of the electron approaches 97% of the speed of light, suggesting potential relativistic effects. Understanding the vector nature of the magnetic force is crucial for determining these force values accurately.
Gavandeshaq
An electron is accelerated through 2.4 x 105 V from rest and then enters a uniform 1.7 T magnetic field. What are the maximum and minimum values of the magnetic force this particle
experiences?
QV = 0.5mv2
F=QvB
Basically, I've got a final value from the above equations, but I'm not sure how to get a maximum and minimum as the problem states. The first equation gives me a speed of 2.9*108
and then putting that into F=QvB gives me a force of 7.89*1011N.
Is this the maximum? Why do a maximum and minimum occur, and how do I calculate them?
Note that the problem does not state the orientation of the magnetic field or the orientation of the electron's entry with respect to that field.
(Also, the resulting velocity of the electron as calculated by "Newtonian" formulas is awfully high -- nearly 97% of the speed of light. Is this problem from a course that "does" Relativity?)
All your equations are good. But I'm not sure what you're asking. Also as gneill said you didn't state the orientation of the field, but I'm assuming that's your variable.
Fb = qv CROSS B, v and B are vectors. Meaning that the least force your particle will experience due to B is when B is parallel to v, and the most is when B is perpendicular to B.
Make sense?
