Magnetic fields - which direction
The discussion centers on the relationship between the direction of current in a flat wire and the magnetic field's orientation. Maximum magnetic force occurs when the current and magnetic field are perpendicular, but the participants debate whether the specific plane of the magnetic field matters. They explore scenarios involving different orientations, such as east-west versus up-down, and how these affect induced electromotive force (emf) in practical applications like a moving car with a vertical aerial. The importance of understanding the magnetic field's direction in relation to the current is emphasized, particularly in exam contexts where angles may be specified. Ultimately, achieving maximum emf requires the movement to be perpendicular to the magnetic field's component.
jsmith613
If a flat wire lies in a north-south direction will the MAXIMUM magnetic force be felt if the field lies either in a east-west direction OR an up-down direction (i.e: ppd to the direction of the current?)??
I know that the maximum magnetic force is felt when the current and field are perpendicular
BUT does it matter which plane the magnetic field is in so long as it is perpendicular?
Also, in exams will it be clear which direction the field is in
(e.g: they might say it acts at a 40 degree angle to the horizontal)
therefore if the current is straight ahead I calculate the component perpendicular to the direction of the current to find the force??
I think the key to this question is the use of the word "flat" in describing the current-carrying wire. That shape should make the maximum B-field happen in only one of the two choices given...
so you're saying that if I had some height as well then it would exclude the up-down direction?
so a block facing in an east west direction would need a mag field in a south-north direction??
also what would happen with an aerial
it has height but basically no depth.
"a car with a vertical aerial 1.2m is moving at 35 m/s. The horizontal componenet of the Earth's magnetic field is 22 * 10-6T. Find the emf induced"
they give me the horizontal compoenent but surely I could also use the forward backward componenet as that too is ppd to the aerial?
Sorry, I'm not understanding what you are saying.
What I was saying was that if you draw a flat wire of some width, going in the N-S direction, then at the same radius R away from the wire, you will get a slightly different B field if you are out at the side (say on the East side, where the B field points up and down), or up towards you (where the B field points East and West).
well what I was trying to understand was how the direction of the mag field is important
going back to this question:
would the MAXIMUM EMF only be possible if I was traveling ppd to the horizontal compoenent of the Earth's mag field (assuming this was the ONLY component)
therefore could I either be traveling straight ahead OR upwards to achieve this maximum EMF??
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
