Is the electric scheme correctly redrawn?
  • Thread starter Thread starter kakadas
    Electric
The discussion centers on whether an electric scheme has been accurately redrawn. Participants agree that the redrawn version appears correct. There is a focus on identifying which resistors are in series and which are in parallel. One user expresses that the additional question about series and parallel resistors was unnecessary, as they found the information clear. Overall, the consensus is that the redrawn scheme is satisfactory.
kakadas
Original:
Redrawn:
Which of the resistors are in parallel and which are in series?
It looks correctly redrawn. Now go ahead and answer the last part about series & parallel...
Yeah, that last question wasn't necessary for me. Now I don't know why I even bothered to ask it everything's clear here...
Oh and Thanks for the help.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
