Convert 24V to 12V for Scooter Horn Wiring
  • Thread starter Thread starter elevfan7072
    12v
To wire a horn to a 24V scooter, two 12V horns can be connected in series for optimal sound output without power loss. Alternatively, a dropper resistor or a 7812 voltage regulator can be used, but these methods require careful calculations and may generate heat. A more efficient option is to utilize a DC-DC buck converter, which minimizes power dissipation and can handle higher current demands. Vehicle wreckers are also a viable source for 24V horns. Overall, using two horns in series or a DC-DC converter are the most effective solutions for this project.
elevfan7072
I recently found a 24v scooter on Craigslist. I would look forward to wiring a horn to it. I don't know what kind of resistor I should use.
Wire two identical 12V horns in series. That is the easiest solution. Alternatively, you are going to need to waste power in a dropper resistor and you would need to work out its value. Two horns in series will produce twice as much noise and waste no power. Plus, you won't need to do any sums!
And the other obvious alternative is ...
there are plenty of 24V horns available for trucks etc
take a trip to your local vehicle wreckers and look through the recovered parts.
many wreckers let you look through vehicles yourself and recover the part you need ... take it to the counter and pay for it
Dave
Oh Or if I only use one I could just use a 7812!
You certainly could, but you will need to figure out the horn current and then how much power that means when you drop 12V across the 7812. Luckily the horn will only be used intermittantly, so it may not take much heat sinking of the 7812 to make it work.
A better solution is to use a DC-DC converter (buck topology) to drop the voltage with little power dissipation. The Simple Switcher series of DC-DC converters from National Instruments is a good place to start if you want to try that route...
you will probably find that the current requird by one 12V vehicle type horn well exceeds the 1A capability of a 7812 regulator chip.
Dave
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
