Kinematics of Euler Bernoulli and Timoshenko Beam Elements
The discussion focuses on the differences between Euler-Bernoulli and Timoshenko beam theories in analyzing beam behavior. Euler-Bernoulli theory assumes that cross sections remain perpendicular to the neutral axis, while Timoshenko theory accounts for shear deformation, leading to additional shear strain. The participants clarify the derivation of certain equations and highlight the implications of using a left-handed coordinate system in the schematic. Practical limitations of Euler-Bernoulli theory are discussed, particularly in cases where shear flexibility is significant, suggesting that Timoshenko theory is preferable for complex or composite beams. Ultimately, for modern applications, especially with finite element analysis, the Timoshenko formulation is recommended for its comprehensive accuracy.
bugatti79
Folks,
Trying to get some appreciation for what is going on in the attached schematic of 1)Euler bernoulli and 2) Timoshenko beam elements.
For the first one, ie the top picture, how was ##u- z \frac{dw}{dx}## arrived at?
thanks
dw/dx is the slope of the beam, which is assumed to be small. So dw/dx is also the angle the beam has rotated, in radians.
The top picture (Euler beam theory) assumes that cross sections of the beam stay perpendicular to the neutral axis. So the angle between a cross section and the vertical is the same as the slope of the beam.
The picture is (stupidly, IMHO) drawn with a "left handed" coordinate system (z and w positive downwards not upwards) which is where the minus signs come from.
In the bottom picture (Timoshenko beam theory) plane sections of the beam do not stay perpendicular to the neutral axis, so there is an extra shear strain (measured by angle gamma) involved.
Ok
I understand this.
Ok, how does the ##z\frac{dw}{dx}## come about? Is this equivalent to Z times the cos of the angle?
Thanks
dw/dx is the sine of the angle (sin θ = θ for small angles) but you are right about the basic idea.
What practical examples are there where one shouldn't use Euler-Bernouilli to track beam deflection etc. Would it for applications of plastic loading?
Thanks
When the flexibility in shear is significant compared with the flexibility in pure bending.
For a rectangular section beam, Euler is OK when length/depth > 10 (some people say > 20).
For a more complicated criss sections, and/or composite beams made from several materials, you have to consider each case on its own merits.
With computer software like finite element analysis, you might as wel always use the Timoshenko formulation. Even if the correction is neglibile, it doesn't cause any numerical problems to include it.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
