Dale
Mentor
- 36,443
- 15,172
I already covered this back in post 83 with my statement: "I cannot think of any philosophical proposition that has any scientific value except for those which are essentially restatements of Bayesian inference."zonde said:Discussions about scientific method are philosophy. Improvements in scientific method like falsifiability are philosophy.
I was specifically thinking of falsifiability and Occham's razor, both of which can be derived from Bayesian inference, which is the mathematical framework for inductive reasoning. So falsifiability is not a counter-example and I stand by my previous assertion.
The term "invariant" itself is indeed defined as a quantity that does not change under coordinate transformations, so that term does presuppose the definition of coordinates etc. However, each invariant physical quantity can be defined without reference to coordinates.zonde said:Can you elaborate on this? First, is invariant defined or is it undefined basic concept?
Because the way it is usually defined i.e. some quantity that does not change under coordinate transformation, is confusing as it is defining invariants using concept of coordinates and consequently coordinate dependant quantities that we are using to construct coordinates. So coordinate dependant quantities are more basic than invariants.
For example, proper time can be defined physically as the time measured by a clock. It can also be defined geometrically as the integral of the spacetime interval along a timelike path. Neither of these definitions require coordinates. Similarly with the other invariant quantities used in physics.
You can define all of your physical theories in terms of these invariant quantities without reference to coordinates. Then, once you add coordinates, you can note that all of the quantities that show up in your physical theories are invariants, and you can refer to them collectively as "invariants" without at all implying that they are less basic than coordinates and coordinate-dependent quantities.
