How do i connect this V-I converter up
  • Thread starter Thread starter riie
    Converter
To create an AC current source from a function generator, a transconductance op-amp can be used to convert voltage to current. A resistor can also serve this purpose, but it may alter the function of the transimpedance amplifier by making it an inverting amplifier. The user is seeking advice on how to connect the left-hand current output to the right-hand input of their circuit. There is confusion regarding the connection points for current flow between the two sides of the circuit. Further clarification on circuit connections and configurations is needed for effective implementation.
riie
Hi all,
I need to have an AC current source for testing but i do not have any equipment that can generate an AC current source. I have a function generator to produce an AC sine voltage and thinking to convert V to I using the transconductance op amp.
The first stage of my test circuit consists of an tranimpedance amplifier with other stages at the back and how can i connect V to I and I to V up? (Ciruit as attached)
Is there any other suggestion for the conversion of the AC voltage source to AC current souce from function generator?
riie said:
Hi all,
You could just use a resistor to convert your voltage source to a current. What is the load impedance of your circuit?
Or else just use the left-hand circuit in your attachment...
If I use a resistor to convert to current, wouldn't the transimpedance amplifier become an inverting amplifier as the resistor will be in series at the input?
Is there a way to connect up the left hand side current output the the input at the right hand side?
Any suggestions?
Does this thread from early February help?
https://www.physicsforums.com/showthread.php?t=669659
The circuit from the thread you have given me, is the same mine with R2 removed.
I'm not sure how to carry this out using my circuit, or another other method.
For my circuit,
- The left side circuit need to the 2 points to be connected for current to flow
- But right side circuit has only one current input point to -ve input
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
