How to Measure Magnitude of Displacement?
Magnitude of displacement is measured in meters and is a scalar quantity, meaning it has no direction. A magnitude of 1 does not imply a distance traveled of 1 meter in one second; that would refer to a speed of 1 m/s. The magnitude of displacement cannot exceed the total distance traveled, but it can be less than it. Displacement can be negative depending on the chosen reference direction, while total distance traveled is always positive. Understanding these concepts is crucial for accurately measuring displacement in physics.
ViewtifulBeau
I have a group of questions requarding magnitude of displacement and total distance traveled. What is magnitude measured in? Is is unitless? If the magnitude is 1 then in one second is the distance traveled 1? Can the Magnitude of the displacement be greater than the total distance traveled? and can displacement and total distance traveled be negative? Thanks
Magnitude of displacement is distance, with a unit of meters. It still has a unit of meters but it does not have a direction. If the magnitude is 1, this does NOT mean that in one second the distance traveled is 1. You are thinking about speed of 1m/s.
No, the magnitude of displacement cannot be grater than distance traveled, only equal at maximum. It can be less than though. Displacement can be negative, distance traveled cannot. The reason displacement could is because it depends on direction as well. If you take north to be positive displacement, then moving south would be negative.
Regards,
Nenad
I have a question very related to this. How do you find magnitude of displacement?
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
