Generate Microwaves Using Heat: Does it Exist?
A device that generates microwaves using heat as a power source does not currently exist. The discussion highlights the potential of using steam to generate electricity, which could then power a microwave generator circuit. However, the efficiency of converting heat directly into microwaves is low, as hot bodies primarily emit infrared radiation. The proposed method involves converting heat to steam, using a turbine to generate electricity, and then employing a magnetron to produce microwaves. Overall, while the concept is theoretically feasible, practical implementations remain absent.
sid_galt
Does a device exist which can generate microwaves using heat (e.g. hot air) as a power source?
You could use steam (and a generator) to make a current, which, when fed into a microwave generator circuit will give you an output at the desired frequency.
Don't know of an existing device though.
Thank you for the help
Hot bodies tend to radiate energy in the infrared range unfortunately :(
Some teeny fraction of the emitted power will be in the microwave range, but if you depended on that you'd have lousy efficiency.
Heat + Water = Steam
Steam + Turbine = Electricity
Electricty + Magnetron = Microwave
Heat => Microwave
:smile:
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
