Solar energy collector formula
The discussion centers on understanding the formula for designing a solar water heater, specifically the term Qs. The formula ^T=Qs / mC relates the change in water temperature (^T) to energy (Qs), water flow rate (m), and specific heat (C). Qs is identified as the thermal energy or enthalpy involved in heating the water. The user realizes that Qs can be expressed as Q = mcΔT, linking it back to their previous physics knowledge. This clarification helps the user feel more confident in applying the formula for their project.
nina
I'm stuck on a formula I'm using to design a solar water heater at uni (and no, I'm not a physics student, otherwise I'd probably be kicking myself its such a stupid question) and I understand the theory behind it, I just can't work out what the Qs stands for.
^T=Qs / mC
where ^T= change in water temp,
m= water flow rate in m/kg,
and C= specific heat of the water
I've tried rearranging the formula but it was never my strong point at A level, and the Qs appears to be representing energy, but of what I'm not sure.
Any ideas?
Q = mc\DeltaT, where Q would heat (thermal energy/enthalpy), m = mass, c = specific heat, and \DeltaT = differential temperature.
Perhaps in ^T=Qs / mC
Q = energy flux (energy/ unit area) and s = surface area, so that Qs = energy.
Thank you!
Now I feel a bit stupid, I knew Q=mc^T from my Physics a couple of years ago, but didnt even see it in this one:rolleyes:
Thanks again for pointing it out.
