What Is the Capacitance of a Parallel-Plate Capacitor with Circular Plates?
  • Thread starter Thread starter physicsbhelp
    Capacitors
The discussion focuses on calculating the capacitance of a parallel-plate capacitor with circular plates measuring 8.80 cm in radius and 1.50 mm apart. The relevant formula used is C = (k * ε₀ * A) / d, where k is approximately 1 for air, ε₀ is the permittivity of free space, A is the area of the plates, and d is the separation distance. Participants clarify the values needed for the calculation, emphasizing the importance of showing work to verify answers. The discussion highlights confusion around the variables R and L, which are not applicable in this context. Ultimately, the correct approach to finding capacitance in picofarads (pF) is confirmed.
physicsbhelp
[SOLVED] Capacitors VERY QUICK EASY QUESTION! PLEASE HELP!
A parallel-plate capacitor has circular plates of 8.80 cm radius and 1.50 mm separation.
(a) Calculate the capacitance.
THE answer has to be in pF for part a)
I don't know what R is, and I don't know what L is. I can assume that A is the area, but the equation your teacher gave you makes no sense to me, as the equation for a parallel plate capacitor is:
C=\frac{k\epsilon _0A}{d}
For air or free space, k is about 1.
There's also another equation:
C=\frac{Q}{V}
Distance of separation.
Area.
Capacitance
Voltage
\epsilon_0=8.85\times10^-12 \frac{C^2}{Nm^2}
Q = charge
1808
I can't say if the answer is right or wrong without you showing any work.
Looks right.
