Parallel voltage sources circuit
The discussion revolves around solving a circuit with parallel voltage sources and determining the currents through resistors R1, R2, and R3. Participants confirm the accuracy of equations used to analyze the circuit, emphasizing the importance of maintaining consistent current direction conventions. The conversation highlights the necessity of defining a reference point for voltage calculations, clarifying that voltage differences can be assessed without needing a specific zero point. Additionally, the concept of grounding in circuits is explored, noting that grounding can vary based on the circuit's environment, such as in space. Overall, the dialogue fosters a deeper understanding of circuit analysis and voltage relationships.
Your equations look fine, although you've provided more equations than are strictly necessary to solve the circuit.
EDIT: Actually, check the sign of the I1 term in your second equation. In your first equation you assumed that I1 was flowing from A to B, so you must maintain that convention throughout. \EDIT
What exactly are you trying to solve for in this circuit, and are you expected to use any particular method of solution?
I see, so the second equation really should be:
Sigma = 0; 20 - I2x2 - 14 +I1x4 = 0
Yes?
Yes.
Good! :smile:
I'll post another problem in your thread, since the second problem there probably won't hold you up for long! :biggrin:
Hehe. I was actually hoping you'd let me find the voltage difference between two points! Can you come up with two points for me?
Sure! VAB?
And can you also give me PAB?
Sorry, but I can't follow your reasoning here.
Anyway, you can't calculate the voltage at a point without defining a reference voltage first (usually earth).
But then, you usually have no need to know the voltage at a point.
You're only interested in the voltage difference between 2 points.
That is what you use and get from KVL.
And also what you use and get from Ohm's law (the voltage "across" a resistor based on current).
What I did is calculate the voltage drop from each voltage loop UNTIL point A, then I added all the remiain voltages together (since I've discounted all the voltage drops).
So when calclating voltage difference I have to set a zero point otherwise I can't solve the thing? And just what exactly is "earth"? Is it A? Is it B?
I still don't understand. :(
:rolleyes: Noooo! You don't set a zero point at all. You don't need it to calculate a voltage difference.
(You only need it to calculate the voltage at a point, and you don't need that.)
Could you perhaps look at the resistor between A and B, look up the current "through" it, and apply Ohm's law to find the voltage "across" it? :shy:
Usually a circuit in reality is grounded.
That is, some point of the circuit is literally attached to earth.
We have a nice symbol for it (actually 2 symbols that mean the same thing).
But without an actual earth, you are free to choose any point to be the zero point.
You can choose A and you can choose B (but only 1 of the two! :wink:).
If we look at each loop individually, the same loops that I composed my equations with to solve for the current, we can see that that there "voltage drops throughout the loops, yes?
For instance, if we take the first loop of the 36V, the voltage drop of that 5 ohm resistor will be Io x 5 = 31.58
When it reaches point A the 36 voltage LOST an amont of 31.58 voltage. Therefor, the remainder is 4.42.
Same with loop 2, until I reach point A, and same with loop 3, until I reach point A. Then I add the remaining voltages together.
Before that let me ask you a question, please.
I present to you case (1) and case (2)
http://img692.imageshack.us/img692/6089/case13.jpg
In case 1, the same voltage that drops through R1 also drops through R2. In case 2, it's not the case, right? Or, otherwise, not "necessarily" the case, because there are other voltage sources complicating things up, aye?
You mean as long as the circuit is not on a airplane/spaceship or anything that flies?
Aye! :smile:Now let me see if I can follow your reasoning.
Yes. :)
Wait! Stop!
Yes, so the voltage difference "across" the 5 ohm resistor is 31.58 V.
Wait! Stop!
There! You have your voltage difference between points A and B! :smile:
Now why would you want to do that?
Did you perhaps look at another solution where they did something like that?
Actually, I remember Gneill did something like that, but he also defined his currents differently.
His method was quite nice, eliminating an equation and an unknown before he even started.
But you have to choose, you shouldn't mix them.
*grins*
Did you never see the long copper wire connecting a plane to the ground? :confused:
Actually on a plane, the circuits would be connected to the frame of the plane.
That is big enough to function as an earth.
Wait! Stop!
Is it not also the "voltage drop"?
Wait! Stop!
What?!? How?!? I didn't even get to point B!
No, I don't have any solutions, just trying to reason out things on my own...apparently not working out so well :-p
Oh, so by "earth" you don't really mean "the ground of planet earth"? It's also the "air of planet earth"?
Yes. It's the same thing.
"voltage drop" does suggest a bit that the voltage is going down.
Whaaaat? Didn't you?
I think you did! :smile:
Keep reasoning! At some point it will say *click*, and then you'll breathe hotly *Aaaaaaaaaaaah*. :blushing:
"Earth" or "ground" is a sufficiently large metal (conducting) body.
Not air, but a plane will have metal stuff attached, that can be used.
It means electrons can flow more or less freely in or out as needed.
I think you did!
Did I? Does that mean point B is my zero point, or my "ground point", if you will?
hotly eh? :wink:
I will keep reasoning, then :approve:
Really? That's how "earth" is defined? I didn't know that...I wish we were told that.
So a circuit in space can't have a "grounding point"?
Hmm, B is still not your zero point.
But since you have a voltage "difference", it will look a bit as if B is zero I guess.
That is, you also have the voltage that A would have if B were the zero point.
There! :smile:
It should be somewhere in your textbook if you have one.
Space... *looking dreamily up*
Well, we'd need to build a spaceship then, wouldn't we?
Let's put some conducting metal in!
If only to ground our artificially intelligent computer with the hot voice! :approve:
Would you be willing to lend your voice to make it happen? :blushing:
I should be somewhere in your textbook if you have one.
Yes, I agree, "YOU" really should be somewhere in my textbook, popping up as a cardboard image, saying all sort of smart things. :wink:
:D Happily, but I still don't get it...so the spaceship would be our earth?
Hmm, I think I begin to understand. So it's basically 4.42V is the "remainder" voltage after the drop of Io, and that's when it hit point A. Okay, can you give me 2 different points?
Aww. I made a typo and corrected it.
But it is funny! :smile:
Yes! We would have a small planet to ourselves! :-p
The point at left-top and B?
And do you also know the power dissipated between A and B?
:biggrin:
But if it was just a circuit flowing in space, would it have a ground point at all? Can a circuit in space function?
Could it possibly equal 4.42+20 = 24.42 [V] ?
Excellent question! But let me take it step by step if you will^^ Thanks
Femme_physics said:
:biggrin:
No, it wouldn't really have a ground point.
It will still function, because a ground is not required.
Let's just say it will function less well.
Uhh... yes, it could! :smile:
Ok, one more to make sure!
The point left-bottom and A?
So the "ground point" is essentially the point touching the surface from what I understand. But what if all the points in the circuits are touching the ground?
Well let's see, if I set Va = 0 then the potentials difference you asked equals 20 - 5.211 x 2 = 9.578 [V]
Yes?
Remember that with "ground" we mean a metal conductor.
If all the points in the circuit touch this ground, we have shortcircuited it, and it won't do anything anymore.
A fuse will probably blow somewhere, since a fuse is usually included to protect against shortcircuiting.
Yes?
Yes! I mainly wanted to check that you were aware of the sign, and that you had to subtract instead of add.
And you were! :smile:
And you were!
w00t! This is kinda fun :biggrin:
So, I guess I should find the power dissipated now. But, I don't get what it really means. Do you want me to find the power? I have a formula for power, not for "power dissipation". Which, is really funny, because THAT IS EXACTLY WHY I skipped a really easy question in my electronic test and tried tackling this kind of circuit which I didn't have enough practice on, and exactly why I got 80 instead of 95 :frown:
So let me try and summerize.
If we put a circuit in space, it has no grounding point.
If we connect all the points in the circuit to the ground point, it will be shortcircuited and it won't do anything anymore
In reality we only ground a single point, and that's the actual point that's touching whatever metal is connected to the circuit.
Is this all true?
The formula for power is the formula for the "power dissipation".
Is this all true?
Yes. :smile:
Is "power dissipation" the power equivalent to "voltage drop"?
Yes
Great! :smile:
Hi PF! :smile:
I see you are working on some challenging linear circuits.
You've done a marvelous job working through to find VAB[ with one method.
Back in post #14, ILS made a suggestion (see above). This may be a good
time to go back solve for VAB using that idea and see if you get the same result. :rolleyes:
(there is a reason I recommend this as you will find later).
  • #31
Yes.
  • #33
Let me see...
The voltage across the 5 ohm resistor is 31.58 V.
So the power dissipated in the 5 ohm resistor is... exactly what you wrote! :wink:
But... the 5 ohm resistor is not between A and B... :confused:
So no, you did not get it.
But the unit you deduced for the power looks very powerful indeed! :smile:
  • #34
I like Serena said:
Let me see...
ILS, perhaps you should have specified the particular component (or components, or path) for which you wanted the power dissipation. Technically, ALL of the components are between nodes A and B, as there is are paths that will take you from A to B through all of them.
  • #35
:biggrin:
Ah, I see the errors of my ways :smile:
I know what to do! *rubs hang together in an evil fashion*
Let me find Ptotal first. Then I shall have the answer, and all the smurfs will be mine!
((PS. Rtotal ends up being 6.33333 ohms ))
http://img824.imageshack.us/img824/8286/hastobeit.jpg
  • #36
Very true! :blushing:
I intended to ask for the power dissipation in the 4 ohm resistor that is between A and B.
Femme_physics said:
:biggrin:
This looks *almost* like a Norton equivalent circuit! :biggrin:
I give you the smurfs. All of them are yours, you *evil* you!
Total power and domination!
Btw, the total power is the sum of the powers dissipated in each of the 3 resistors (I get 259 W).
  • #37
Easy peasy!
P2 = 2 x 5.211^2 = 54.31 [W]
Muwahhaahahhah!
Btw, the total power is the sum of the powers dissipated in each of the 3 resistors.
You mean
Pt = Power dissipated in resistor 1 +Power dissipated in resistor 2 + Power dissipated in resistor 3?
In which case, I was aware of that! :approve:
And I did get the correct result, yes?
  • #38
Femme_physics said:
Easy peasy!
Muwahhaahahhah!
You mean
Let me see...
We got a total power of 258.65 W.
Subtract 199.46 W from your previous result.
Subtract another 54.31 W that you just got.
That leaves... 4.88 W for the 4 ohm resistor between A and B.
Yes! That's it! You got it! :smile:
  • #39
w00000000000000000t :biggrin:
You rock!I'll probably do the other one tomorrow^^ You're incredible, ILS! This is pretty fun for me, I don't know about you :wink: You're a life saver. I'm pretty stressed about term B in electronics, it's my last chance at "redemption" for this course.
  • #40
Neh, this is no fun for me. ;)
  • #41
You did a nice job ! (!עבודה טובה)
There are typically several approaches to the same question.
Some take fewer steps than others. :smile:
Here is the method I was suggesting you try.
(It may help save you some time on an exam)
You found currents for the initial question to be I1=1.105, I2=5.211A and I3= I0 = 6.316A
Next was find VAB and PAB (with respect to R1).
V= IR ; VAB = I1R1 = (1.105)(4) = 4.42V
P = IV; PAB = I1VAB = (1.105)(4.42) = 4.88W
  • #42
Duly noted Quabache :smile:
Next time I will certainly be wiser :approve:
I will try me hands on another exercise this morning (it's 4:30 AM here. I'm an early riser!)
  • #43
I like Serena said:
And here's a second one.
Perhaps you can start a separate thread for this problem?For the circuit shown below, determine the voltage for each of the
resistors and label the values on the diagram.
That was pretty easy. I didn't find P for each just for lack of patience. I know I know it!
http://img18.imageshack.us/img18/8364/otherquestion.jpg
  • #44
Hmm, it seems you've been progressing...
But wait! You did not get all the smurfs! :smile:
Which smurf did you miss?
  • #45
Yea I know finding the P in each of them...but com'on you just apply a formula it's soooooooooooooo easy! Lemme skip that pretty please? :smile:
  • #46
I like Serena said:
How about this one?
[PLAIN]http://img25.imageshack.us/img25/4407/circuitj.jpg[/QUOTE]
First question--
How come they get to pick for me the direction of I? Shouldn't I be the one determining it?
  • #47
Not that. You made a mistake.
Perhaps I should have said that you dropped a smurf?
  • #48
Femme_physics said:
First question--
Well...
Look at the drawing in your first post in this thread.
You did not mark the directions of the currents (and as a consequence you made a mistake with it).
So I thought I'd better mark them for you! :devil:
(Just kidding, I just picked the first exercise that fitted your description. :wink:)
The real reason would be that the people who made the exercise would want the same answer from all students, so it's easier for them to check the answers. This means naming the currents and preselecting the directions.
  • #49
  • #50
I like Serena said:
Well...
Interesting. So you get different answers if you pick different direction for I? I didn't know that!
