Stationary elevator homework problem
To solve the stationary elevator problem, consider Allison's apparent weight when accelerating upwards at 8 m/s². The scale measures the upward force on her, which can be calculated using Newton's 2nd law. By adding the acceleration to the standard gravitational force of 9.8 m/s², the effective gravitational force becomes 17.8 m/s². Consequently, Allison's apparent weight is her mass multiplied by this new gravitational force. Understanding these concepts clarifies how acceleration affects perceived weight in a stationary elevator scenario.
ryan1357
I'm doing this Physics worksheet and I don't know how to do this problem...
Allison is standing on a scale that is in a stationary elevator. what is the apparent weight when she is moving up at 8 m/s squared?
If anyone can help that would be great.. And if you could explain the steps you used to get it.
Thanks
The scale reads the force that pushes up on the girl. Draw a diagram showing the forces on the girl (there are two). The net force on the girl is related to her acceleration by Newton's 2nd law. (Hint: you can express the girl's apparent weight in terms of her actual weight.)
Just think of the acceleration upwards as more gravity.
The "gravity" has increased from 9.8 to 17.8 m/s^2.
Therefore her apparent weight is just her mass times the new "gravity".
