Can Rearranging V=L x di/dt to V=i x dL/dt Describe Voltage Changes in Coils?
  • Thread starter Thread starter hobbs125
The discussion centers on the rearrangement of the formula V = L x di/dt to V = i x dL/dt, exploring its implications for voltage changes in coils. It is argued that a decreasing inductance could produce an opposite polarity across the coil compared to an increasing inductance. The conversation highlights that changing flux causes an electromotive force (EMF), regardless of whether it results from a change in current or inductance. An example provided is the behavior of solenoids and capacitors in specific applications, such as in electric pianos. The potential for small-scale applications using coils is also considered, indicating interest in practical implementations of the discussed concepts.
hobbs125
V=L x di/dt is a well known formula used to calculate the voltage across an inductor due to a collapsing magnetic field.
It seems to me that the formula could also be arranged to say:
V = i x dL/dt
Voltage is equal to current times the change in inductance...
If this formula is true would a decreasing (collapsing) inductance produce an opposite polarity across the coil than an increasing inductance?
if I wind two coils together and connect them in a series circuit so they oppose each other. When the pulse goes through the coils it would cause the inductance to change (drop to zero) and induce a voltage across the coil? Could the equation above then be used to calculate the voltage across the coil?
Are there any applications where this is used?
V = i x dL/dt
[STRIKE]
This is absolutely not true.[/STRIKE]
EDIT: Clearly I misunderstood something!
Absolutely true.
Inductance is defined as flux(linkages) per ampere and the changing flux causes an EMF irrespective of whether it resulted from change in amps or change in inductance.
That's why a solenoid creates a dip in the current as its airgap closes.
jim is right. i haven't seen this done with inductors, but i have seen it done with capacitors (in a Wurlitzer electric piano). in both cases, it's a consequence of the product rule of derivatives:
i(t) = C(t)\frac{dv(t)}{dt} + v(t)\frac{dC(t)}{dt}
i think the counterpart for coils is:
v(t) = L(t)\frac{di(t)}{dt} + i(t)\frac{dL(t)}{dt}
The explosively pumped flux compression generator is an example of this.
Jim Handy,
That's exactly what I was thinking. And I don't see any reason why that rearrangement of the formula is wrong.
The_emi_guy,
Could this be done on a small scale using coils as I described above?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
