Electric Field Due to Dipole Problem
The discussion focuses on calculating the electric field due to an electric dipole as a function of the perpendicular distance from its center. The initial attempt incorrectly included an extra square root in the expression for r and did not properly express sinθ in terms of x and d. After correcting these errors, the revised formula for the electric field is kqd/[(d²/4)+x²]^(3/2). Despite confidence in the corrected math, the solution faced issues with Webassign not accepting it. The final consensus suggests that the calculations are mathematically sound, but there may be external factors affecting the submission.
Renaldo
Consider the following figure.
For the electric dipole shown in the figure, express the magnitude of the resulting electric field as a function of the perpendicular distance x from the center of the dipole axis. (Use the following as necessary: k, q for the charges, x, and d.)
Et= E1 + E2
E = k|q|/r2
The x component of the electric fields will cancel out, leaving only the y-components. Adding the two vector fields in the y-direction:
[k|q|/r2]sinθ + [k|q|/r2]sinθ = 2[k|q|/r2]sinθ
r^2 = [d/2 + x^2]1/2
My final answer:
2[kq/[d2/4 + x2]1/2]sinθ
This is not correct.
Et= E1 + E2
E = k|q|/r2
My final answer:
For one thing r^2=x^2+(d/2)^2. You've got an extra square root. For another, you should be able to express sinθ in terms of x and d as well.
Yes, I noticed that extra square root. When I fix things up, and set sinθ equal to d/2r:
It's a lot of algebra, but it comes out to kqd/[(d2/4)+x2)]3/2. Does that look right?
Looks ok to me.
Dick said:
Looks ok to me.
All right. Thanks. Webassign doesn't like the answer but I feel confident in the math. Could be a problem with Webassign.
