Vectors delta velocity calculations
The discussion focuses on calculating delta velocity (Δv) between two waves originating from points A and B, given their travel times t1 and t2. It is established that if the distance between A and B is constant, the speeds of the waves can be expressed as d/t1 and d/t2. The formula for Δv is derived as d(t2 - t1) / (t1t2). However, if the distance d is unknown, calculating Δv becomes impossible. Understanding the relationship between time and velocity is crucial for this calculation.
NMann
Hello,
Two waves originated from point A and point B, waves are 'velocity-direction-dependent', can be treated as 'vectors', it took t2 time for the wave from point B to reach A, and it took time t2 for the wave from point B to reach A.
Given the fact the two vectors have the same 'magnitude', and only the t1 and t2 are known is there a way to calculate delta velocity?
A>>>>>>>>>>> B, in t1 time
B>>>>>>>>>>> A, in t2 time
Distance between A and B is constant, and only known variables are t1 and t2, is there a way to calculate Δv?
thank you!
Mathematics news on Phys.org
Is it a known constant value? - or it is an unknown value, just known to be some constant?
If the distance from B to A is d, then the first wave, taking t1 to go from B to A, has speed d/t1. The second wave, taking t2 to go from B to A, has speed d/t2. The "\Delta v" is d/t1- d/t2= d(t2- t1)/t1t2.
If you do not know the distance from B to A, then you cannot calculate \Delta v.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
