DC Motor Field Current Speed Control
The discussion centers on using a Geared DC Motor rated at 12V and 0.6A with a field current control circuit for variable speed. The proposed circuit was deemed ineffective because the resistors would act as an additional load rather than controlling the motor speed. A 555 Pulse Width Modulation (PWM) circuit is suggested as a more efficient alternative for speed control, emphasizing the need for proper components like transistors instead of potentiometers for high current applications. The circuit design should ensure that the control device is in series with the motor to effectively regulate speed. Overall, a PWM approach is recommended for better performance and efficiency.
OvaR8ed
I have a Geared DC Motor rated 12V, 0.6A, 180RPM, 3kg.cm, 66% Efficiency. I measured the impedance of the disconnected motor at 45 Ohm.
I want to use it with a with a simple 12V 1A DC Power Supply in a Field Current Control Circuit to be able to dial in variable speeds.
Will the circuit in the attached diagram work?
What are good Theoretical Resistance values to start with for R1 and the Potentiometer to give me a wide range of speeds with no load on the motor?
For which Wattage should the Resistor and POT be rated to deal with the currents correctly?
Thanks in advance!
That circuit won't do anything. The resistors are simply another load on the 12 volt supply.
Yeah, I realized that. It could work if you limit your current at the power source, but that will over complicate things.
I'm rather going with a simple 555 Pulse Width Modulation circuit...
first of all yes for high amps a pot will be a waste of enrgy you have to use switches like transistors, the other thing the device needs to be in series with the motor , you circuit as you probably realized by now is in parallel with the motor so the motor would still go full speed.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
