Can I Safely and Neatly Regulate Power for My Chameleon's Habitat?
  • Thread starter Thread starter aronweiss19
    Distribution Power
The discussion centers on creating a safe and organized power distribution system for a chameleon's habitat, which requires careful regulation of lighting and humidity. The original poster, a teacher, seeks to consolidate multiple devices into a single setup while ensuring safety from electrical hazards. Concerns are raised about the poster's limited electrical knowledge, with advice suggesting consulting a local electrician for compliance with safety codes. Participants recommend considering pre-made solutions like the EcoZone controller to avoid potential risks. Overall, the conversation emphasizes the importance of safety and proper planning in electrical setups for exotic pet care.
aronweiss19
Greetings all,
This is my first post, and I preface by saying I attempted to search for a solution before posting. Accept my apologies if this topic has been covered in some way; I'll gladly move/repost.
Anyhow, here is the situation: I am a teacher and my students are aged 9 - 12 (Mixed grade level class). We have a class pet, a chameleon. Being that chameleons are relatively exotic they have fairly demanding needs for a stable habitat. They require appropriate lighting for heat regulation and color/wavelength for proper metabolism. This particular species (Chameleo Clyptratus) also requires finite humidity regulation (between 70% and 80%). Consequently the process of plugging in all of the lamps, pumps and humidifiers makes me nervous, both with consideration to load and the presence of water.
Now, I run four lights, an ultrasonic water atomizer (for humidity) and a water pump (to pump water from a larger reservoir to the humidifier.) All of these are plugged into various surge protected power strips with automatic timers to regulate the bunch.
I've calculated the draw and I'm at 6.7 amperes for the circuit, so I feel like the amount of stuff I've got running is relatively safe. I would however, like to have things be both neater and safer.
The problem:
What I would like to do is set up a power regulation/distribution panel the provide as much protection against shorting, fires and shock as possible. I am, however, not exactly sure how to do it. What follows is the general idea I've concocted so far.
I want to run the whole setup from one (or two) grounded plugs into the wall. The plug(s) go through one (or more) AFCIs to a distribution board which then power four GFCI outlets (8 total plugs). After adapting the cord length for each various component, I would then be able to plug in and run all of the components from the GFCI plugs.
The whole setup would be built onto a board that hangs behind the chameleon's enclosure. My goals are to:
1. Keep things as safe as possible
2. Eliminate as much excess wiring as possible
3. Have a single location for power distribution and regulation
4. Keep the set-up such that I can easily disconnect and reconnect components
5. Power the entire habitat from a single cord and outlet
Bonus 6* wire everything up in a way that I can regulate the lamps, pump and humidifier through a program, likely run with my Raspberry Pi.
My Questions:
1. Is this reasonable?
2. Does my design concept reflect what I want?
3. What components would I need to build such a monstrosity? (The GFCIs seem easy enough, but I'm concerned about the 'distribution' point and how to hook up an AFCI to the whole kit.)
4. Tips and tricks on the "how" to go about wiring everything up
All that said, as I'm sure you have gathered, I have an elementary understanding of this stuff at best. I've made simple projects in my time, I can use a multi-meter, I know how to solder, and I can crunch the math for volts, watts and amps.
Thank you kindly for taking the time to read, and I look forward to your responses!
-Aron
p.s. Please feel free to correct my nomenclature and usage.
aronweiss19 said:
...I am a teacher and my students are aged 9 - 12 (Mixed grade level class).
... I have an elementary understanding of this stuff at best
These are two good reasons that you should NOT attempt this build. I would consult a local electrician who knows the "codes" for keeping you and the kids safe.
I appreciate the criticism. You do bring up valid points.
I do wish to continue this discussion, however, being that one of the mission goals of this site is to... "learn and discuss." I see room for improvement in my personal understanding, and the opportunity for a interesting public conversation.
If nothing else, I would appreciate a chances to discuss my ideas with knowledgeable experts. Any input is still greatly appreciated.
meBigGuy said:
Here is the right answer (or better yet, just get a bearded dragon :) )
http://ecozonevivarium.com/products-vivarium-controllers.aspx
Nice find. I've been googling and this is similar to what I envisioned he wanted to do. :-p
The EcoZone controller is basically what I'm trying to mimic, with the goal being to stay under the $400 price point.
That is quite similar to what I had in mind. Nice find!
UPDATE: Just read the wikipedia article associated with the picture, took note of the UL and NEC violations. Looks like the EcoZone is the way I go!
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
