Urgent Dynamics and Mechanics Help: Difficult Energy, Work, and Power Questions
The discussion focuses on a user seeking urgent help with a series of challenging physics questions related to energy, work, power, elasticity, and coplanar forces. The user expresses feelings of desperation and requests detailed guidelines and complete solutions for 11 specific problems, highlighting their struggle to make progress. Respondents emphasize the importance of students working through problems independently while offering to provide guidance and support without solving the questions outright. The conversation underscores the need for a deeper understanding of the underlying physics concepts and encourages users to consult tutorial sections for additional resources. Overall, the thread reflects a common challenge faced by students in mastering complex physics topics.
Scarface_Joker
Hi guys - this is going to seem pretty demanding for a first post but I am desperate.
I have a series of 11 questions here spanning Energy/Work and Power, Elasticity and Coplanar Forces that I need masses of help with. I'm finding them to be the most difficult questions of any subject I've ever had to do, I don't know whether you guys will feel the same or indeed find them easy.
Just assume I haven't gotten anywhere, which for most of the questions is true. I'm in need of guidlines on how to solve the whole problem, complete solutions would be an absolute godsend.
I'm really sorry for such a laborous post, but I am almost at the point of a breakdown.
Questions
1.Find the power required to raise water 3 m vertically from a tank and
discharge it through a nozzle of cross-sectional area 0.0003 m^2 at a speed of 10 m/s.
2.A mass of 1 kg rests on a horizontal table. It is connected by a taut, light, inextensible string passing over a smooth fixed pulley, at the edge of the table,to another mass of 3 kg hanging vertically. The 3 kg mass is at a height of 0.5 metres above an inelastic floor when the system is released from rest. There is also a frictional resistance to the motion from the table of 0.5 N. Determinethe total work done by the frictional force, assuming that the 1 kg mass stops before reaching the pulley.
3.A mass of 5 kg is attached to one end of an elastic string of natural length 2 m and modulus of elasticity 10g N, the other end being attached to a fixed point A. The mass is held at A and allowed to fall vertically. How far below A will it first come instantaneously to rest, assuming that there are no obstructions in its path?
4.One end of an elastic string is fixed to a point A on a smooth horizontal table.The other end is attached to a heavy particle P of mass m. The particle is pulled away from A until AP = 1.5l, where l is the natural length of the string, and is released. If the string's modulus of elasticity is mg find the velocity of the particle when the string reaches its natural length.
5.A mass is suspended from a point O by an elastic string of natural length l so that the length of the string is 5l/3. Show that if the mass is allowed to fall freely from O the greatest length of the string during the ensuing motion is 3l.
6.An elastic string has natural length a and modulus of elasticity mg. One end is attached to a point O and the other to a particle of mass m. If the particle is held at a distance 4a below O and then released, find the height above O to which it will rise.
7.A uniform rod AB of length 2a weighs 10N. It is freely hinged to a vertical
wall at A and is kept in equilibrium by a string CB of length 2a (C vertically
above A) such that AB is inclined at 30° to the horizontal. Find the magnitudes and directions of the tension in CB and the reaction at A.
8.Forces of 3 , 4 and 6 Newtons act at 30°, 60° and 120° respectively to the horizontal. Find the horizontal and vertical components of the resultant and hence its magnitude and direction.
9.Forces of 1, 2, 3 and 4 Newtons act along the sides of a regular hexagon
ABCDEF of side a in the directions BA, CD, ED and FA respectively. Find
the magnitude and direction (with respect to ED) of the resultant of this systemand also determine where it cuts DE.
10.A uniform beam AB of length 6 m and weight 11 N rests horizontally on two supports C and D, where AC = 1 m and DB = 2 m. Weights of 6 N and 7 N are hung from the end points A and B respectively. Calculate the reactions at each support. What extra force must be applied at B in order to cause the beam to just lift off the support at C?
It is customary for the student (poster) to show his/her work.
Please try to write the equations for each problem. Presumably, the physics and related equations are discussed in one's textbook or covered in class.
As a policy we do not solve problems in their entirety. We do work through problems with students, but students must do their own work.
Also, please check the tutorial sections.
