Fixing a Broken Laptop Power Inlet
The laptop's power inlet may be damaged after a fall with the charger plugged in, likely affecting the ground pin. The user is considering repair options, weighing the possibility of using a soldering iron against sending the laptop back under warranty. Experience with soldering is noted, but concerns about the tight space on the circuit board and the absence of the broken part complicate DIY repairs. The consensus suggests that sending the laptop back is the safest option, despite concerns about the potential wait time for repairs.
exequor
my laptop fell on its power inlet with the charger plug in it and I think that something might have been broken. whatever is supposed to be at the back of the inlet, or at the end of the charger is what i think broke. My assumption is that it is the ground pin. how should I go about fixing this, I could return it since it is under warranty but I don't know how long acer would take to get my laptop back to me—my assumption is that it would be a long time. how should i go about fixing this?
Computer science news on Phys.org
Is it broken or bent?
Do you have any experience with a soldering iron? if No, then just send it back to them and have it repaired, you'll be better off in the long run.
It is broken. And I don't have the part that broke off.
Yea, I'm used to soldering, but since i don't have the part that broke off, what can I substitute? Plus I'm not too sure where it has to be soldered back.
Laptop circuit boards tend to be pretty tight with not a lot of room between component solder points. Unless you have really really stead hands and a really really fine tip on your soldering iron, you stand a good chance of soldering together bits that shouldn't be soldered together. Then you'd really be up the creek without a paddle. Easiest thing to do is send it back
I should send it back, but I really cannot do without my laptop for the period of time which I assume it would be gone away.
I came across a video regarding the use of AI/ML to work through complex datasets to determine complicated protein structures. It is a promising and beneficial use of AI/ML. AlphaFold - The Most Useful Thing AI Has Ever Done https://www.ebi.ac.uk/training/online/courses/alphafold/an-introductory-guide-to-its-strengths-and-limitations/what-is-alphafold/ https://en.wikipedia.org/wiki/AlphaFold https://deepmind.google/about/ Edit/update: The AlphaFold article in Nature John Jumper...
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
