Calculate Energy Needed to Heat 4.6 kg Water
To calculate the energy needed to heat 4.6 kg of ice from 0 degrees Celsius to vapor at 106 degrees Celsius, multiple equations are required. The process involves four distinct steps: first, calculating the energy to melt the ice into liquid water; second, determining the energy needed to raise the temperature of the liquid water to 100 degrees Celsius; third, calculating the energy to evaporate the water into vapor; and finally, finding the energy required to raise the vapor to 106 degrees Celsius. Each step utilizes specific formulas: Q = mcΔt for temperature changes, Q = ml_f for phase changes from solid to liquid, and Q = ml_v for phase changes from liquid to vapor. Summing the energy from all four parts provides the total energy required for the entire heating process.
runicle
Determine the energy needed to raise the temperature of 4.6 of 0 degrees celsius ice to 106 degrees celsius vapour given the values for water: 5 marks
l[subscript]f= 333kJ/kg, l[subscript]v = 2255 kJ, c[subscript]liquid = 4200 J/kg c[subscript]vapour = 2000 J/Kg degrees celsius
I just have one question, do you need all these equations?:
Q = mc[delta]t, Q = ml[subscript]f Q=ml[subscript]v
and basically add them all up?
yup, that's right
I can tell you that it is a four part question.
A) Energy to melt the solid ice.
B) Energy to raise liquid to 100.
C) Energy to evaporate into vapor.
D) Energy to raise vapor to 106.
